Help, my throttle says Idle and I don’t know and can’t find the command sequence to ahhh… Unidle it. [:(]
Merry Christmas All
DD
Found it duh the command is power then + key.
Merry Christmas All
DD
There is no sequence. IDLE means it’s not seeing your UR92 when you unplug it. Unless you’ve somehow managed to get into the throttle settings and disabled Duplex. It’s int he manual.
Idle means the commaand station is turned off. Joe.
