Digitrax Duplex Radio Throttle Idle Problem
I have a Digitrax Duplex UR92 receiver and a DT402D Throttle.The Throttle will not go to idle when the DCS100 is in sleep mode. Has this been a problem with any one else? The DT100Rs will idle.
I don’t know. I turn the batteries over when I’m not using them.
Did you try the suggestions made when you posted this question the last time?
http://cs.trains.com/TRCCS/forums/t/206812.aspx
