I’m going to see what the driver wheels will do when they arrive. It’s currently for sale on eBay, so if it doesn’t sell, I’ll let you know and I will take you up on the offer if I can’t get it to run right. Thanks for the offer man!
Sorry about that. They used to show the drivers. I think? I have ordered several of these and maybe I am mistaken has I know what I have received.
You wonder what goes on sometimes. They will show you a picture of a part that you can’t order because it is no longer being made, but no photos of some thing you can buy. Go figure?
Yeah, it’s kind of annoying. Oh well. I hope this fixes the problem. If it doesn’t, I’ll send it to you and the drivers, or I might actually send the drivers back. If the drivers work, I’ll hold onto the engine. I certainly can’t sell it.
When you install the drivers don’t install the side drive rods. Leave them off. This way there is no chance of the side rods and drivers to cause any binding. Just a thought.
I got the new set of driver wheels. I installed all four, but there was a clicking sound on one of them that was bugging me. So I took off the second and fourth set, and the clicking was still there. Plus, the third set of driver wheels was slightly binding at very slow speed. So I took off the third set and replaced it with the original third set, and it ran better, but not up to my OCD perfect standards.
I then checked the width of the wheels on the engine and tender, and the third wheel on the tender was a tenth of a MM too tight. So I adjusted that, and the thing runs like a swiss watch now.
I have learned my lesson: if a set of driver wheels need to be adjusted, just get a new set that has already been balanced and adjusted for me and don’t try to adjust it myself. I’ve ruined probably close to $350 worth of steam engines by checking the clearances of the driver wheels and adjusting them myself, or I’ll use a tool to do it.
So be it, but in the greater scheme of things, it was money well spent because it gave you an opportunity to build up a wealth of knowledge that you can use going forward. Congrats.
This Kato has restored my faith in Kato a little more. With the traction tires, this thing pulls very well, although not as well as my Model Power 4-6-2 Pacific. Now I have to decide if I want to run wires to the tender for a sound decoder.
If you go to a sound unit you can put back the weight that you removed to install the non- sound decoder and it might help a bit in the pulling department. I have several of these units and they pull about 17 cars up a 1.5 % grade through a 15 inch radius 90 degree curve. For the wires I suggest you use a super flexible wire from North West Short Line. It is called 29 51 I believe. You will need five wires. Two for the motor and two for the pickup and one more for the H/L. There is no need to run the blue wire from the decoder to the H/L for power, you can power if from the light board in the boiler. This is a tight fit if you use the SoundTraxx Tsunami decoder. To get capacitors to fit I use two surface mount 20 volt 100uF caps in place of the original cap that comes with the decoder. Wire them in parallel, which will give you 200uF.A 14X25 MM speaker will fit under the coal load.
After three separate times of trying to sell it, I will not be selling it now. I’ll be keeping it and trying to stuff a sound decoder in the tender.
Digikey does not have SM 100uF 20V capacitors, unless I missed something. They have 16V, which would work for my DCC system, but not MRC’s DCC system which is 16.2V.
