First of all, which system do you have? The details will vary depending on the system, but in general, you press the Program key, until the bottom middle of the display says Pg for paged mode or Pd for direct mode, either will work for a TCS decoder. If you go past the one you want, just keep hitting the Program button, it cycles around through the 4 options.
Turn the LEFT throttle knob counter-clockwise until the display says AD2=???, this is for setting a two-digit address.
Turn the RIGHT knob to dial in the address you want, it has to be 127 or less.
Press the Enter button.
That’s it. Straight from the manual. If you are hitting any other button, you’re not reading the manual.
Now the details, if you have a DCS100, Super Chief Xtra system, you will have the loco on the program track, which is a seperate piece of track connected to the Prog A and Prog B terminals on the DCS100. If you have a DB150, Super Empire Builder Xtra, there is no seperate program track, so you need to be sure no other locos are on the rails, or they will also be programmed.
If you have a Zephyr, or Zephyr Xtra, the loco will be on a dedicated program track connected to the Prog A and Prog B terminals on the unit (they are NOT next to each other, the Ground terminal is in between them)
On a Zephyr/Xtra, you pres the Prog button, until the display says Dir. The press the Loco button, the display will say either AD2 or AD4, press the loco button two switch between them. If you want a two digit address, select Ad2 and then key ion the address you want using the numbers. 1-127 only. The press CV-WR to write the address. That’s it, again, straight from the manual.
