Digitrax SFX064D Sound FX Decoder , good or not?
Question for all you guys that know about this sound decoder.I want to put a sound decoder in some of my dummy engines but am reluctant to buy one wheni have no knowledge of the decoder.Saw the this decoder on ebay for abour $ 60 bucks but would like to get some feed back on it.If you guys have any info on a good fairly cheap sound decoder to install in gp-38’s,40’s , 40-2 etc let me know. I already have a Union pacific with factory sound but ,would love to put sound in my southern pacific’s .
Thanks
Chris
http://www.trains.com/TRC/CS/forums/1127828/ShowPost.aspx
Take 5 minutes and read the thread. It will tell you everything you need to know.
David B
Thanks David, i appriciate it, that is what i was looking for, dont remember seeing the thread?
Chris
I have two Tower 55 models with the new Digitrax SoundFX decoder in them, and the sounds and motor control are very good.
As per usual on these forums, useful threads usually get buried and the useless off-topic ones stay on top.
David B
Cacole,
Which Tower 55’s do you have? I have a couple of ES44AC’s(UP’s so I suppose they are C45ACCTe’s) and agree on the motor control but find the sounds, while clear, are limited. They also aren’t the best pullers, even after run-in.
I didn’t realize/make the connection you were in Siera Vista. I spent Three months at Ft. Huachuca last year and would have liked to say Hi.
And I put an FX combo decoder in my Kato SD38-2, which sounds and runs well, again with limited sounds.
Tilden
You need to unlock your sounds…with the PR2
David B
And I didn’t even know they were in prison. Doing 8 to 10 for fraud I’ll bet.
So, there are additional sounds on the chip and I need to buy the PR2, which runs through a computer to access them? Does this go for diesel as well as steam? Is there info on the Digitrax web site regarding the sounds available?
Tilden
Tlden,
My two Tower 55 models are the ES4400ACs decorated for the SP Black Widow fantasy scheme. All of the sounds work fine in mine, so I don’t know why you’re having problems with them.
I am using an NCE Wireless ProCab with them set on the default values as they came from the box, except for resetting the address and adjusting a couple of the volume CVs.
