Soon after it was released, I purchased the new duplex radio throttle and receiver. I have been really happy with it and decided it was time to send my old DT400 non wireless throttle in for the upgrade. Less than 2 weeks later my upgraded throttle arrived today.
So for $65 my 6 year old DT400 was upgraded to the latest DT402D specification. This included the F0-F28 function upgrade, duplex radio, new front label, a full printed DT402 manual and return shipping. I have to say that I am impressed and very happy with the service.
If you upgrade to the DT402D can it still be plugged in and used as before the change over? Mine is sitting in a box and now would be a good time to send it in.
Thanks for the information, Simon. For those who might be interested, what else would one with, say, a Super Empire Builder, have to do/purchase in order to get a working duplex system? Can the DB150 also be sent back for an upgrade, for example?
“Duplex” refers to two-way radio communication between the throttle and the Loconet, so the only thing that needs to be added to any Loconet-based Digitrax system (IOW, any current production) is a UR92 (duplex receiver) and a DT402D (duplex) throttle.
yes MOJAX, it can be used plugged in, BUT!! when converted to any radio type the lead that you use to plug it in gets shortened to about a foot in length so it limits the movement somewhat. but using an extension lead gets you back to what you had before with a bit of a lego brick in the line.
Depends on what you have in the box. If it’s a DT400 (no radio) it can be upgraded to a DT402 (no radio), DT402R- simplex radio to work with a UR91 receiver, or a DT402D- duplex radio to work with the UR92 transceiver. All three versions will still have infrared cordless capabilty.
No changes to any ather Digitrax equipment are needed.
The long coiled cable is removed and you are left with the short piggy tail cord, so an extension would be necessary for real tethered use.
All the throttles have the built in IR solution for use with the UR90 IR receiver
The DT400R and the DT402R work with the UR91 simplex radio receiver
The DT402D works with the UR92 duplex receiver/transmitter
To make any Digitrax layout wireless, you just have to add the appropriate UR and throttle combination. There is no upgrade needed for the command station.
In my case my command station is the Zephyr. Even though the Zephyr only supports limited functions, the addition of the new throttles gives me the F0-F28 without the need to upgrade the Zephyr.
Are you sure? I know that you cannot get the simplex radio in Germany, but my understanding was that one reason they went with 2.4ghz for the duplex radio was so that they could sell it in Europe.
winnetou is correct at the minute. i live around the EU too and emailed digitrax about upgrading to duplex radio. the email i received in reply stated just the US and Canada. it may be on a legal frequency for europe, but as yet it has not got the necessary licences/licencing to be ‘legal’ for use here, even though the frequency used is. just a matter of time and money at a guess?? that said, it is usually not a crime to ‘own’ transmitting equipment, just to actually use it. there is no need to plug in the UR92 and the 402D can have the radio disabled in the OPs settings of the throttle. that said!! we all know if you have it you’re going to use it .[:-^]
my reply was on 10/05/09, i response to the US/canada reply i asked how long it would be for EU use and got another response saying it was in the hands of the authorities
This is why Digitrax products are great. Nothing goes to waste and when new technology comes out it will work with anything that was produced prior to it.
So if I have a DT400 and a DCS 100 and send it to Digitrax with 25 dollars it will increase the functions from the 12 to 28 is this correct what about the utility throttles like the UT4s can they also be upgradeed for more functions
Phoebe Vet answered the DT400 question, and yes $25 turns it into a DT402. As for the UT4 utility throttle, there is a new version coming out in early November. The UT4D, but this continues to have the F0-12 functions. I imagine that UT4’s will be able to be sent in for the radio upgrade, but there is no provision for the additional functions. Without a redesign of the throttle it would not easily be able to support additional functions as it does not have enough buttons. There would have to be some sort of double shift function, which would be cumbersome. I already find the single shift cumbersome enough.
There is one additional benefit to upgrading a DT400 throttle to any of the DT402 versions. These new throttles can have their firmware updated via computer. New firmware can be downloaded from Digitrax and with a locobuffer or PR3 your DT402x can be updated at home.
There is a free software application that you can download from the Digitrax site. I had to use it on my first throttle as some of the very first DT402D’s went out the door accidentally with some pre-release firmware. I simply plugged the throttle into the loconet and the software took care of the upgrade. I use a Locobuffer 2 and it worked just fine. It took several minutes, but the layout is fully operational while the upgrade is going on.
