I’d like to create a plug on the back of my layout for my Zephyr system. (I juts bought a UT4). The Zephyr manuual says to use RJ12 6 pin connectors. The local Radio Shack says they have nothing matchin RJ12 in their computer. I bought a 6 pin connectore that they sell for telephones, but it doesn’t seem to fit the Zephyr plug. Is RJ12 called something else, or I am just lost?
I haven’t tested it, but it is closer to an ethernet jack. At any rate, you can get the real deal Digitrax for about $15 for a two-jack plate.
There’s a document on the Digitrax Web site entitled “LocoNet Wiring” that says it uses standard Telco RJ12 six-conductor crimp-on plugs.
Radio Shack is not a good source of these parts – you need to consult a better mail order source such as Mouser Electronics, All Electronics, and DigiKey for the proper parts, or find a better electronics supply house near you other than Radio Shack.
If you can deal with premade cables in set lengths - you can actually get the correct cables at WalMart! In the phone section. I think they ave 3, 6, 9, 12, 15, and 24 foot lengths.
I’m about ready to start doing my fascia and panels, so I will need to make a run over to the local Graybar. That’s where I get all cable-related items - spools of Cat5 for my home network, etc. But I needed one 6-foot cable to connect my Locobuffer to the Zephyr so I just grabbed one a WalMart.
For your actual panel jacks, Chip is right, use the real Digitrax panels. It’s what they’re made for.
Randy – Just got back from Wal-Mart. $3.46 and I’m in business!
I’m always amazed at the quality of the folks on this forum. Thanks, all, for the willingness to share the knowledge and the time. Those of us just starting out really benefit!!
-Jack
