The diorama base is 1/2" plywood it mesures 2’x3’. It will eventually be moved around because I plan on transfering the actual train layout to another room
I’d go with my old standby, Aleen’s Tacky Glue. It’s a craft store product. It goes on white and dries clear in a couple of hours. It holds firmly but if you want to take something off that’s pretty easy, too.
I don’t glue my structures down. I use K&S brass rod and tubing to keep them in place so that they are easily removable. I use a couple of short pieces of 1/16” OD tubing in each of my structures and in the base where the structure is placed. I use a removable .03” brass rod for a snug fit as a connector, that combination leaves both the structure bottom and ground/base without obstructions with the rod removed. A second advantage of using brass to secure your structures is for power for lighting.
Brass tubing flush with the ground is very hard to see so I can remove a building or vehicle without it being obvious.
I’m one that is never satisfied with my layout so having everything easily removable is a must for me. There is always something new just around the corner that can be added or modified, having easy access for mods really helps.
Hello Mister Beasley, Mel, Howard and Broadway Lion.
Thank you for all of your suggestions, they are all greatly appreciated.
I have all of the above suggested products on hand; since my structures don’t all have a flat base I will have to expirement to see which one is best or maybe use different adhesives.
The Brass tubing technique is quite interesting but I think lining up upper and lower tubes can be fastidious, unless you can suggest an easy line up method.
I only have one structure that can be tedious, it’s at full arms length in the middle of my layout. The rest are relatively easy once you adapt to lining up the rods. Vehicles are a snap and I constantly move them around my layout.
Some of my buildings are held in place with gravity and a piece of foam core.
Others have been permanently attached while I fixed the ground cover with 50/50 white glue/water mix. In this case, the building can be removed after soaking the ground cover with water.
It sounds like one move from a diorama to the railroad. Ken Patterson mounts some of his structures on a flat base (like foam core) and then uses a router to create recessesed area in the foam base. Sounds messy to me but he can pick up a stucture and move it somewhere else.
I can appreciate that stablilizing your delicate building is important but remember model railroaders are prone to revisions so a permanent mount is not necessarily desireable.
If you need a gap filling adhesive, the silicone caulk / glue may be the way to go. It is thick and dries rubbery. Any excess can be cut away with an X-Acto knife. I use GE clear; it is availble in a container sized a bit larger than a toothpase tube, so you can get a small one to try it out then go with the caulking gun size it you like the result. The building can be removed with little work in the future if necessary.
Another real tough glue is Liquid Nails for Projects. Read the labels, the original tan colored glue is not plastic friendly; the white kind is. This is a strong adhesive, and you probably would not be able to remove a building in the future without damage. it also comes in a ‘toothpaste tube’ size for for testing.
