Display Shelves
This is my first post here. I will finally be moving into a new home with a room just for trains! So I plan on devoting 1 or 2 walls to display O-Guage trains. It seems that the 2 companies in CTT with a similar product are Glenn Snyder & Showcase Express display systems. Has anyone had experience or recommendations with these? Any advice will be appreciated.
Personally I’m sure both are a very fine products, but would make them myself first. ( out of wood seeing your going to have to put them up yourself anyway. ) It’s not that hard to do. I believe if I remember right if you have a table saw if you cut a grove at 1 3/16th on each side you will have the with of the track to put your cars in. ( check first with a small piece of wood. )
Welcome
The units are really nice looking and work well, but are expensive.
I used some 3/16 glass cut 3 1/2" deep and as wide as needed for shelves out of salvaged glass with 3x3 “L” braces, if interested in an alternative.
Again, welcome to CTT
Jim
No experience with them, but I too would make my own. I made mine out of wood. It can be as simple as using 1x4’s, and a table saw to put grooves in for the wheels set in. Painting them, and mounting them with simple metal corner braces.
Lowes and Home Depot both offer 1" x 4" in a white ( painted) so you can get buy without even painting them. I did that with about 1/2 of what I have and the other I stained in a dark oak ( I think ) see pic. this is some of the ones I stained.
Here’s how I do it (as recorded by Dave Vergun years ago):
http://cs.trains.com/ctt/f/95/t/60920.aspx?page=2
[#welcome] aboard!
[#welcome] Lackawanna Joe,
I have Glenn Snyder shelving and in my opinion you can’t go wrong with them.
I don’t think you would be disappointed if you chose to go with them.
This is how I installed them.
Those do look really nice![Y]
Jim
There are other companies out there also. I have something called Trainshelf. They advertise in the TCA newsletter.
One option that you may not have thought about is to look for used shelving. I bought 700 feet of used aluminum Trainshelf for about $900 on an auction. One of the best buys I did with trains. I estimate I saved around $2,500, not including what shipping of the brand new product would have been.
Oh, and a tip on attaching aluminum shelving, should you go with that option. I went to Menard’s (A Midwest home improvement store) and bought boxes of white hex head screws for attaching metal siding to pole sheds. They just take a nut driver on your drill and they have a rubber grommet on them, so they snug up nice without scratching the shelves.
NWL
