display track
Iam trying to find a powered display track with rollers so i can operate a display engine . Any help will be appreciated . RON
Micro Mark has 82896 (assembled) and 83176 (kit), but it sounds like you are looking for track with rollers, rather than the rollers standing above the rails. Could you scenic in front of the little blocks and have a piece of track coming in from each end to look like the track the engine was on. Just a thought.
Another thought. If it is steam, could you block the engine up, just above the rails, using tender pick up for power.
Good luck,
Thanks . It doesn`t really matter if the rollers show or not . Thank you so much for the info . I have a bli n & w a class steamer i would like to be able to run and hear the sound until i can build a layout . Thanks again . RON
http://www.micromark.com/HO-and-On30-LOCOMOTIVE-ROLLERS-ASSEMBLED-SET-OF-4,8274.html
or
http://www.walthers.com/exec/productinfo/160-42901
