My layout is a large 20’ x 24’ double deck walk around. Right now I am struggling a bit with control panel location.
Option 1 and my original plan is one main panel per town. The panel will have momentary pushbuttons to activate the tortoise machines, lights for turnout position and lights for block occupancy. This could result in at operator having to walk 5 or 6 feet to throw a switch. While not bad it could get old when switching industries
Option 2 is individual panels at eash switch or group of two to three switches. This would prevent the walking but may not be as clean as a signle panel.
Also thinking block occupancy lights on a local control panel are redundant when one can just look at the track. I will still put in block occupancy for signaling and ctc.
Each of my turnout control panels covers an area roughly 10-12 feet. I don’t find it at all incovenient to throw a switch. I have wireless walk around throttles. For route control, I throw the switches well before the train reaches the turnout. For industrial switching, the panel is usually no more then 5 feet from the turnout that needs to be thrown.
I am much more inclined to use option B. I prefer to have the control for the turnout close to that turnout. Since I have a continuous facia on both levels of the layout, a small spot in the facia for name or diagram of the track with a turnout control is not a big deal.
Just prefer the on location feel to the tower or dispatcher feel of a remote panel.
For me, not that much thought at all on control panels. I do have ON/OFF fascia-mounted switches to control which tracks are active or not, and there are also a number of electrical switches to control some turnouts which are otherwise out of reach. The rest of the on-layout turnouts are finger activated (to flip the points into the proper position), while those in staging yards are controlled with Caboose Industries ground throws. I also use Blue Point turnout controllers, too, mostly for hard-to-reach turnouts.
A few photos…
These fascia-mounted switches no longer get used much at all…
They were installed mainly so that I could choose from a number of walk-around throttles, with which to run trains. Once I got my Stapleton throttle, I seldom use the other ones.
The power for the trains, an MRC ControlMaster 20, is visible under the layout, while one of the plug-ins for the walk-around throttle can be seen to the right. There are another 5 mounted on the fascia at different points in the room, plenty enough with a 25’ cord on the throttle. The train will continue to run with the plug removed, as I follow it and move on to the next plug-in point.
This is the fascia at Lowbanks, where there’s a turntable, the toggle switches controlling power to a variety of in-town tracks and the rotary switch controlling which turntable track gets power or not.
The scratchbuilt turntable is not motorised - strictly finger-controlled, while the pinball-style knobs control otherwise hard-to-reach turnouts, through Blue Point switch machines.
The turntable tracks are controlled by this rotary switch…
Larry Pucket the DCC guy on YouTube just did an episode on building a wireless control panel for his railroad. He used DCC specialty equipment and tortus ground throws. You could make a pair and take them with you when operating.
I have a small panel in the main yard, thats it but my layout is small. On my last layout that was just as big as yours but not double decked I did the same thing as had walk arround there too but that layout was DC as current is DCC.
It appears that operating using a dispatcher is not high on any of the responders layouts. The dispatcher usually acts as the tower man establishing and switching routes as well as train priorities
My layout may be similar to what you have. I have 20’x20’ 2 level layout, all walk around, no duck unders. It’s designed for operations with a total of 6 operators. There are signals on the upper level which are controlled by the dispatcher. I have 2 dispatcher panels right next to each other, which control 2 interlocking main line switches on the upper level. The yard has a separate panel, controlled by the yardmaster. Any industries off the mainline have their own panel which is controlled by the operator switching out that area/industry.
At one time I had some switches that a dispatcher controlled as well as the yardmaster, but it became more prevalent to have the yardmaster control it.
The lower level is for staging trains and is operated by whomever is getting a train of sending it to staging. Panels are at each end of staging, so an operator doesn’t have to run to both ends to pull out or put back a train.
I built three control panels for my first 5x12 foot section. The idea was that the panels could actually be repositioned from one side of the layout to the other. That turned out to be sort of silly, and I never actually did it. I added two more panels as the layout expanded.
I did a few area with stationary decoders, so the panels were just turnout position indicators. I also realized that I preferred real panels.
I have decided on a main panel for staging and another for the yard. Beyond that there will be individual push buttons at each switch. The push buttons will tie to DS,-64 and DS-74s.
I am also going back and modifying blocks on trackwork I have already started to allow for signaling. These new blocks would require many more occupancy lights on the panels which seems like it would be too much clutter. Another good reason to drop the multiple panel idea.
