Hi,
I’m fairly new to DCC but have tried a few things on many decoders & have been pretty successfull.
However, I have a challenge with an Atlas QSI based Dash8-40CW & her Ditchlights.
I have set them to the following & here is what “I see” when I place the Loco on the Run track;
In Idle the Ditchlights are off.
In FWD they are on/Bright
Horn will only flash while the tone is coming from the speaker or horn held engaged (continous) on the hand throttle (not a 5 Second hold, from initial horn trigger)
Stop/Idle they are off
Reverse they are off
I have programmed them using JMRI & here is the system info readout;
Settings\Administrator\JMRI\systemfiles\messages.log [main]
15 apps.AppsBase INFO - Gui3IDE version 2.14-r19563 starts under Java 1.6.0_31 at Sat Jun 02 21:52:54 CDT 2012 [main]
1515 serialdriver.SerialDriverAdapter INFO - NCE COM8 port opened at 9600 baud [main]
1656 nce.NceConnectionStatus INFO - NCE EPROM revision = 6.2.1 [AWT-EventQueue-0]
Using an NCE PowerCab 5Amp, & a DCC Specialties PowerPax Programming track booster on it’s own dedicated 14" Kato track section, & the Run track is also another seperate Kato 14" track section.
What should I be seeing with those settings shown above?
The desired effect that the Ditchlights are performing are;
On Dim at all times except in: Forward, -on Bright, & -flash for 5 seconds from the initial horn
