dn147a
bought an atlas n sd60m already equipped with a digitrax dn147a at first it ran fine for awhile then i tried setting up a consist that only worked for a few seconds before it quit running but the other loco still worked and the light on the sd60 also worked any ideas?
What DCC system are you using ? What type of consist did you set up (Advanced or ? )
When all else fails, program a value of 0 into CV 19 to kill the consist address, or reset the decoder to factory default settings and start over (CV 8 = 8)
using an nce powercab tried both old and advanced consists will try cv19
problem was the motor tabs
