Is it just me or do operating accessories with vibrating Motors seem to work better once they get hot, or at least warm? Seems to me that 14 volts is never enough to get them going at first. Seems like after 5 minutes or so they start working nicely. My only thought is the heat has something to do with it. I’m referring to accessories such as rotary beacons, radar antenna, and windmill that use the vibrating motor.
Never made this observation. Here are my thoughts,
Heat is not really a bi-product of the classic Lionel vibrotor. I have noticed that the fingered washer in the vibroter will wear down or dry out over time and what you are experiencing may simply be a symptom of an old washer.
Washers are very inexpensive so if you have an old one try replacing it and see if that makes a difference.
I know on both the rotary aircraft beacons i have the coil gets hot. Maybe the coils are bad??
About the only thing I have with a Vibrotor-type mechanism is a 140 banjo signal and, while it doesn’t seem to need to get warm temperature-wise it does work better after getting warmed up (i.e., operated) and run a bit.
