The 2055 has the pill type smoke unit that still works. Is it really important I keep using the pills in the smoke unit? Would it burn out if I don’t?
Pill smoke units are pretty durable. You won’t burn one out even if you run it dry.
I use liquid smoke in my pellet smoke units all the time. It works fine, however don’t give them more than three drops of smoke fluid or so at a time-otherwise, you’ll run them over.
With that said, however, I just bought some reproduction pellets from Trainz.com. They work exceptionally well, and allow you to get that great pellet smell. They also beat paying $20+ for poor condition original pellets.
Thank you. I’d like to get some smoke pills though. It’ll really make me travel back into time. I’m also wondering what smoke pills would smell like.[swg][swg]
With that said can you put American Flyer smoke in the new and old Lionels?
Back when I was into American Flyer, a lot of the guys around here used the Supersmoke cedar scent in their engines. That’s also what I always used.
After rebuilding a few AF units that had been used with Supersmoke, I vowed to never use it again in anything. It left a gummy mess in a wick that was only a few months old.
If, on the other hand, you’re using the reproduction AF fluid that R.F. Giardina sells, I don’t think that it will cause a problem.
Thanks Ben!
