I ask this question because I just installed a new Tomar Industries double search light using the identical resistors on each of the four red and green wires that I used on the first Tomar Industries double search light some 9 years ago.
This newest signal is considerably brighter than the ones that I installed back in 2004.
Yep, I have been using the same resistors, with the same values, for years. I simply follow the instructions and the recommendations made by Tomar, the manufacturer.
They kind of do, but by an ‘old’ LED, we’re talking a lot more than just a couple of years old. Such as, compare two early LEDs, from when they first became commonly available over 40 years ago - one that has been in continous use and one new in the pack (hmm, wonder what a NIB never used 1971 LED would go for…) you may be able to detect a difference. And you’d need a large sample size, not just 2, to be sure it wasn;t manufacturing differences, unless the two in question were from the exact same batch.
Which is what you are probably seeing - simply normal manufacturing variation from batch to batch. At the proce of today’s LEDs, I doubt they are doing any super tight controls on process variation, at least not on the ones they sell for pennies a piece.
And then there’s the dropping resistor being used - if you are using a common resistor, they are 10% tolerance. It is entirely possible that, with a pair of “1K” resistors, to have them 200 ohms different between each other - one the full 10% high, and one the full 10% low. It’s VERY likely that there is a 100 ohm difference - one 5% high and one 5% low - because if the resistor was closer then 5% off of the nominal 1K value it would have been binned and sold as a more expensive 5% tolerance part. Though a 100K difference may not result in a visible difference int he brightness of the LED. But multiply that up if the resistor is bigger than a 1K - say the recommend and you uses a 2.2K, that could be a 440 ohm difference in values and very likely to be enough current difference to change the visible brightness.
Going back to the early LEDs, I remember wanting to experiment and not being able to afford many LEDs, they were well over $1 each. There was a circuit for an LED array oscilloscope in one of my electronic magazines - the LED array alone would have cost over $200 to build. At today’s LED prices - maybe $15. I did eventually build one as my senior project in colle
I grabbed another resistor and placed it in line behind the first resistor and the LED grew a little dimmer.
I don’t want to simply replace the existing resistor with one of higher value because everything is already soldered and heat shrunk in place.
But, I could add another resistor in line behind the existing resistor. What is the resulting resistance?
Say, for example, that I have a 1.5K ohm, 1/2 watt resistor already in place. Then, I add another 1.5K ohm, 1/2 watt resistor next in line. Is that a 3.0K resistor value, or something less?
Or, I could just do some trial and error to match the brightness to that of other close by signals.
While there is probably some reduction on light output over time, LEDs are solid state devices and will eventually just fail. Unlike a lightbulb that has decreased output because tungsten vapour condenses on the glass envelope during operation, reducing light output.
What you are probably seeing is a combination of advances in LED fabrication and maybe a different supplier. Different suppliers will have subtle differences, even between batches. You may also be seeing the effect of different resistors. Again, different suppliers have variations between them. Or the tolerance of the resistors is different, maybe 5% versus 10%. They may sell them as 10% when in fact, they failed qualification as a 5% device by being 6% out. Resistors can shift in value over time as well, usually increasing in resistance.
Get a 5k pot from Radio Shack. Set it to max resistance. Put the pot in place of the original resistor. Slowly turn the pot shaft until you have the same brightness. Remove the pot and use your ohm meter to measure the resistance of the pot. Put in the nearest value. I have done that a few times. Not a big deal.
I agree it’s an issue most likely caused by variance in resistor values. 10% ones are pretty notorious for catching folks up building circuits that need to be a little more precise to work well. 5% and 1% ones can get expensive, but do save this being an issue.
This resistor calculator may come in handy dealing with adding resistance in series or parallel to correct:
I have a fairly large selection of 5-packs from Radio Shack on hand. I have had these resistors for a while now, but the Tomar Industries Double Search Light that I installed today is brand new, just purchased. So, I suspect that it is the LED, not the resistor.
I have a whole bunch of Tomar single and double search lights on my layout. What I have observed is that the older the search light, the dimmer (or maybe I should say less bright) the LED. I have always used resistors with the same values from the same source (carbon film resistors from Radio Shack).
If it’s a case of using the LEDs as supplied in a kit, there can be a big difference in light output solely because of variation in batches. I’m sure Tomar buys in large quantities, but equally sure there’s variations in batches.[C=:-)]
It could also be the case that improved chemistry, substrates, etc means that what you’re see may be brighter LEDs in production, even if the spec is technically the same. It may not be so much any dimming of old LEDs, but that the new ones are general brighter.[I]
These Tomar Industries search lights are pre-built, assembled and wired, and ready to install right out of the box.
Tomar does not supply the resistors, but it does recommend 1.5K for the red and 680K for the green. I have faithfully followed this recommended value with each resistor that I have installed for these bi-polar LEDs.
My power supply is the DC side of an MRC 1370 Railpower transformer. It has an 18 volt maximum, and I have the rotary dial turned all the way up. Yesterday, I experimented by dialing it down a little, and that dimmed the new search light LEDs, but, of course, every other LED connected to the power supply dimmed as well.
I do like Richg1998’s suggestion of using a pot to determine the ideal resistor value, and I will do that today. I will report back with the results.
Actually, my answer to Tom’s question was not entirely accurate.
When I said, Yes, I check the actual resistance before installing a resistor, what I meant was that I selected the resistor with the resistance value stated on the package.
After I re-read this thread, especially Randy’s reply, I put my ohm meter on several different resistors.
I make sure that the ohms aadjustment properly set to zero and I installed a new battery before testing.
I am finding variances of 25 to 30 percent, unless I am doing something terribly wrong.
I measure resistance on a 330 ohm resistor and get a value of 250 ohms.
I measure resistance on a 560 ohm resistor and get a value of 440 ohms.
To assure myself that my multi meter is working properly, I tested the AC volts and the DC volts on my power pack and I get exactly accurate output voltages.
If I am doing this correctly, it is no wonder that the LEDs on the new signal are so bright.
Can resistors deteriorate sitting in a plastic box for years?
Not likely, but one thing to keep in mind is calibration of the meter. Just because the volt function may be dead on does not mean the resistence calibration is correct. Also, the resistence function relies on the internal battery, if the voltage is slightly low due to it being an older battery, this will throw off the results, even though there is plenty of power to drive the display. Same applies to an analog meter, plus you have to be wary of parallax when viewing the pointer against the scale.
Most meters will list int he specs somewhere the accuracy of each range. So you worst case for a given resistor reading would be (assuming a 10% resistor): nominal value - 10% of nominal - meter tolerance
So if it’s listed as being accurate within 10 ohms on the 1K scale, a 330 ohm resistor could read as low as 290 ohms, assuing everythign else is operating within parameters, such as the battery. And then there’s the contact between the probes and the resistor leads, and the probes and the sockets on the meter. When you start getting into lower resistor values, a slight difference in the pressure applied between the probes and resistor leads starts to become a factor. Stick something bigge ron, like a 10K resistor and see what you get.
I use 4.7K SMT resistors to make detection wheelsets. They are something better than 10%, they might even be 1%, I’d have to go look on the box. With the silver conductive paint and a clean wheelset, my fancy but older desktop Fluke (which has not been calibrated in over 15 years) reads about 5.16K. I think it’s pretty accurate. i don;t have a small enough set of probes to measure one fo those tiny resistors directly. I’ll try some of my 1K resistors I use for headlight LEDs as soon as I can get back to the bench. I know this meter is quite sensitive - it can tell the difference between a piece of #14 wire and connecting the ends of half the spool.
Checking the battery is something I always do if I suspect an incorrect reading. I often forget to mention that when I suggest using a meter. Another good reason to have more than one meter.
