I’m just dipping my toes in the world of DCC and experimenting with installing DCC decoders in my existing locomotive fleet, including some that were purchased DCC ready (or equipped) and others that were not. Two of them are 3rd version Bachmann GE 44 tonners, which came equipped with DCC decoders. On both, I originally removed the decoders and lighting circuit boards because I installed them into a pair of General Electric steeplecab electric freight motor bodies (a MEW brass body, replacing the original open frame mechanism, and a Shapeways plastic body.) At the time, I only ran DC and removed the decoders and circuit boards to fit the chassis in the body, and because I didn’t need the original lighting circuitry (but I kept the parts, just in case.)
After I switched to DCC, I reinstalled the Bachmann-supplied decoder (which has a very compact body) in one, and a Digitrax DH126 1.5 amp decoder in the other, in both cases wired directly to the motor and track power. The mechanisms of both are otherwise identical, but the motor with the Digitrax decoder ran much more smoothly than the one with the Bachmann-supplied decoder. I later replaced the Bachmann decoder (the one I had reinstalled) with another Digitrax decoder, got better low-speed performance and the motor ran more quietly.
Have DCC controllers changed over time and provide smoother/more power, or are these quality differences of different brands of decoder, or some combination of both? Obviously there are other differences with the decoders (the Bachmann only has 2 functions for forward and reverse lights) but are there other differences in how they provide power to the motor?
Pictured below are some of my DCC converted fleet so far, including a GE 70 tonner (originally a two-motor DC chassis, replaced with a newer 70 ton chassis with DCC equipped), a 2nd generation 44 tonner (originally “DCC ready,” I was able to install the 3rd gen lighting board and decoder in it, it drives the motor but the LED headlight
