Greg,
Signal systems have to be adapted to endless possible track arrangements.
BUT, at its most basic level, at an interlocking, the top head indicates the status of the mainline or highest speed route.
The second head indicates the status of the next highest speed/importance route, the third head indicates the lowest, most speed restricted route - even if the routes are not phyically in that order.
The branch to the yard may be the first route you physically come to, but it will be indicated by the bottom head.
So, a single turnout interlocking would have a two head signal as you approach the points. If the top head is green, the turnout is set for the main and the track ahead is clear. The bottom head WILL be red in this case, there is no other choice.
If the turnout is set for the diverging route, the top head WILL be red, and the bottom head will be red, green or yellow depending on the speed restriction and track status ahead.
So, if you approach that turnout and see R/R, you do not know which route is set, but you don’t need to know that, you know that you have to stop. But when the signal changes, then you will know which route is selected. If the top head goes green or yellow, the mainline route is set, including the turnout.
If the bottom head goes green or yellow, the diverging route is set, including the turnout.
You can believe me or not, I don’t have 100 pages of prototype “proof” at my fingertips to direct you to. And I don’t have time to dig thru my library, search 70 years of MR for articles, etc, to give you references to look up.
Sheldon
