Check out this link. It seems to be stirring a bit of interest among railroads. I also think that Morrison Knudsen tried to market a switcher way back in the 90’s.
Sadly that is because the railroads decided they could us older road locomotives for yard work…I am surprise that several of the major railroads still have them…After all a older GP38 can do the work of a much older SW1500.
Although it’s maybe slightly a bummer to have less variety of locomotives for our model railroads as we move into the future, in real-world terms, that is recycling at it’s finest!!!
I’m becoming more and more certain that I’ll need to pick a definate prototype date for my model railroad for reasons such as this - the real world just changes too much!
Late add: Whoops - I missed the Railpower links in a couple posts above. Mea Culpa.
You guys have missed the most significant change in locomotive technology recently - the Green Goat. Take a Geep (usually a -7 or -9) frame and trucks, and build a new switcher on top of it.
Geep units (GP were just that, general purpose, they could handle a variety of jobs.
About like the old Shay to handle everything.
A “Switcher” design would likely have a smaller engine, use less fuel than the full sized version, so it would be a better economy, why some switchers had no-engine slugs with powered trucks, no speed but it could pull!!
Any railroad has to consider how their engines do what.
There is a steel mill in Arkansas where I pick up steel once in awile and they have a contraption that they use to shuttle cars around the plant with. Now this may not qualify as a switch engine, but I’ll attempt to discribe it. First it appears as a manucfactured engine, not a home built. It looks like a large tractor with rubber wheels and the railroad wheels are mounted under it at a 90 degree angle so you can drive it over the tracks lower the rail wheels onto the track and travel sideways down the track. I’ve seen it pull-push 8-10 loaded coil cars. I would say it qualifies as a switcch engine but would not be seen leaving the plant only to pick up or return cars to a siding of the railroad serving the mill.Just something I thought would be of interest to you, Ken
Other than the early days of diesel, there really weren’t that many purpose-built switchers in the first place. Plenty of steam switchers started life as mainline engines, then they got old and had their pilots replaced with a coupler and found use as a yard goat. Many of those old puffers met their death when the first generation of diesel switchers came out, since diesel-electrics weren’t as powerful as the biggest steam they found acceptance as yard goats first.
So, I imagine that once the current generation of old Geeps finally throws in the towel, we’ll see a generation of new hybrid switch engines along the lines of the Green Goat to take their place.
A good thing about old switchers is they can be overhauled so they last a long time.I work at a large grain elevator and we use a NW2 built in 1947 and a pair of GE 35 Ton models made in the 1950’s.Yes,they are fun to operate.AFAIK another of our elevators still uses a Baldwin DS 4-4-1000. We used to use Trackmobiles but they were to small.
Here is a question: for the Railpower Green Goats, I wonder how much noise they make? I’m betting they sound a lot like a simple generator set - a constant, relatively quiet drone.
Be awfully boring (but very easy) to make a sound chip for!
