do you DC or do you DCC ???
I was just wondering how meny model railroaders are still going the way of DC?I myself am and will most likely stay DC. I have a 14 x 24 lay out with two main lines and a fairly good size yard all on blocks . When we operate we have to be on the ball or Casey Jones comes back to life ! I’ve seen DCC in action and it look to be great , but i guess i just like to work . W hen a train is headed south and one north i better have switches thrown and blocks on . Well thats just one man opion. It may not be right and may not be wrong. STAY ON TRACK and keep the fire hot !!!
hi there i am still using DC and find that turning on blocks is not hard at all.
DCC too expensive for me, with a limited budget
I concur with Shaun .No Operating Problem with DC.
I have two ovals, two separate packs, blocks and can run three on the outer and two on the inner.
As the faster catches up, just throw a block.
For new comers, DCC deserves your full consideration/evaluation.
Chuck Walsh
I spend all day trying to get embedded real-time software and hardware to work together. DCC is too much like work.
Who doesn’t have a budget to run?Most with a few exceptions.I understand that for a model railroader who already has a great working DC layout and for whom it represents a hefty investment,DCC represents a major investment.It becomes an extra that he can go along without and still enjoy his layout since he is drilled to the procedures of controlling a DC powered setup.
However,for many like me who haven’t started purchasing any hardware other than a power supply and a few tracks,I believe that DCC is the way to go,definitely.I haven’t investigated all the otions yet,but I think that on the long run DCC is not much more expensive than DC,maybe even cheaper.And when you add the features of DCC,it becomes a much better options.I’m planning on going DCC but I understand the DC guys,they have a very good point.
I suspect that DC will continue to dominate the hobby until the current older generation of modelers passes into history. Far too many have built their layouts around DC operations and the costs to change over would, in many cases, be prohibitive (too many locos to convert). I’m a DC’er and haven’t the slightest intent of converting to DCC in the future.
It is an interesting point that, in spite of all the hype DCC gets in the magazines, I have yet to see a scientifically accurate survey on the question that currently gives DCC anything larger than 15-20% of the market share. There does not seem to be any great rush by hobbyists to convert and for many older modelers I think the played-down complexities of DCC are often too difficult to deal with.
CNJ831
Got to remember that manufacturers like the Atlas Master series, Trix and Broadway already include a DCC chip and the list will grow.
Reminds me of when I was a kid RC airplanes were starting to become popular and all the line flyers basically threw a fit and used the same arguments to attack RC, too expensive, to complex, to much work, not enough “fun”. Fast forward 25 years, when’s the last time you saw a line plane flying at the park? FRED
I operate using DC a lot, but being an electronics nut , I also have some equipment
with analog command control and some with DCC I operate these at different times
when not on DC. Eventually I will be able to operate them simultaneously using my
CMRI (computer model railroad interface). The problem I have is not enough time to
operate in any mode !
Robert
DCC.
And DCC’s improved operationality is even more effective on a SMALL layout. A small layout does not have the space for a lot of blocks, without command control it is very hard to have several locomotives running at once.
Starting from scratch, DCC is not significantly more expensive than straight DC. Compare a Digitrax Zephyr, Atlas Commander or MRC Prodigy cost to two good power packs (MRC Tech 4 for example) and a dozen dpdt center off toggles. Decoders are under $15, and even those offer more features than is possible with DC.
NIGEL.
WELCOME BACK!
Your input is always top notch.
Chuck Walsh
I started my layout in DC but got interested in DCC because of the things that I could do simply as I am not electronically inclined. The main line is done and I run two trains around from one Digitrax throttle and am having fun.
The options that are available in DCC are tremendous and growing all the time. I didn’t find the conversion expensive but I hadn’t purchased all the necessary equipment to set up in DC.
DCC it’s the way to go. Once you go DCC you don’t go back. It’s much more realistic and not very expensive anymore.
DCC. Love it. I’ve been in the hobby since 1932. Been there, done that. The only complaint I have is that I’ve found no one to install decoders properly. Bob Hall
When the Cochise & Western Model Railroad Club’s layout was re-built from scratch several years ago, we knew we would eventually have DCC, so the layout was wired with switches on the control panels to rapidly change from DC to DCC, so those members who did not or could not afford to invest in decoders could still run their older locomotives. We still have that option available even though most members have invested in decoders, because some locomotives are too old to be worth trying to convert to DCC. During open houses we always run strictly DCC because of the improved control. Those members who still have not installed decoders into their locomotives have to run other members’ items during the open houses. After every open house, those people ask me to install decoders into their locomotives, because they become converts during the open house weekend. Initially, many members, myself included, resisted DCC because of the cost of decoders, but as prices have dropped and they have seen what DCC has to offer compared to DC, nearly everyone now has at least two locomotives with decoders in them. I foresee the day in the not too distant future when no one still operates on DC block control except modelers who have large fleets of very old locomotives, especially as more manufacturers produce locomotives with decoders already installed.
Wow DC or DCC, that is the question. When you have 35 blocks and 4 cabs now, do you change to DCC. Most of my equipment is Hobbytown, varney, pennline or large motered units. They pull 3/4 to 1 amp easy. Decoders are expensive at that level. Yes anyone new should be in DCC. Us old ones will stay with Aristo Radio controls. Last switch position my be DCC later.
Hal March Eastern Gully & Gorge RR The Cracked EGG Route We are Scrambling to get there hsmarch@comcast.net
I DCC, and I love it. I got into the hobby just as DCC was coming available. I started with a Digitrax Big Boy and later upgraded to the Chief setup. I can’t say it’s cheap, but it isn’t that expensive compared to the benefits that I see it offers. I’m pretty well hooked on sound and have installed Soundtraxx decoders and speakers in my locomotives. The sound of a pair of Consolidations or Light Mikes double-heading a freight up a grade makes it all worthwhile.
I switched to Digitrax in 96 , yes it was expensive then, but I never regret changing over.
With todays lower cost it is the only way to go… once tried, you’ll never go back to DC.
And ALL those switches…YUK!!!
DCC. Bought a Digitrax Chief a few years ago (Worked lots of OT that summer and thought now or maybe never). Really have never used it except to test run locos but got to run on another layout sometime later and the owner actually ran with the Chief. And he had sound in about half a dozen locos. Wow! I had read all the literature from all of the manufacturers and am happy with my decision. My layout is under construction but I feel a lot better knowing how simple the wiring will be compared to all the other layouts I’ve built in the past. I can’t see a real cost difference in the two systems except when you’re thinking about adding sound and that will probably continue to come down in price. Thankfully I haven’t converted too many of my locos to DCC and now with sound being more viable (cost) it’s a matter of how many locos can one afford to do in perhaps a years time. Anyway, I agree with cacole about modelers using DCC and right away wanting to convert one or two of their own locos to use on a DCC system. I’m not saying there is anything wrong with DC-used it for almost 30 years but when something comes along that is such a leap forward why not use it?
Well since I’ll be modeling a granger, flatland railroad for one thing, I probably will end up going with DC as I don’t see any major advantage to using it in my situation and operation. Yes, I realize that DCC is growing, the wave of the future, and here to stay, and I have no problem with that type of progress and inovation in our hobby… I just don’t see ME personally feeling a need to be going there, and with all the locos I’d have to add decoders to.
Now, as I see “new and improved” decoders, sound, etc. starting to come out, does this mean current ones will start becoming obsolete and all need to be replaced every couple years? God, it’s bad enough I have to replace a perfectly good computer system every few years. Imagine if we had to replace all the decoders in our engines a couple times per decade as well. I also read where DCC seems extremely sensitive to shorts as when a loco derails or runs a switch or some such. Lets admit it, as much as we don’t like to admit it, these types of things are pretty typical, and on a regular basis, on MOST layouts, no matter how careful we are or how fine tuned we like to thing our level of operating skill is.
What works well for operators around here, and what I will probably end up doing as well, is just to have the operator drive the train, and the dispatcher flip the power switches on a panel as he assigns running rights to various trains via radio. Seems fairly analagous to a real DX flipping the CTC panel selectors, whatever. And that’s “good enough” for me and I have no problem with that scenario at all.
As I say, I have nothing personally against DCC or it’s users, I just don’t think it’s where I need or even especially want to be on my railroad. And I kinda like seeing switches flipped and indicator lites being activated, etc.anyway. Must be the kid in me!
Best,
