Not sure if this has been asked or discussed. If it has, sorry for the repetitiveness.
I’m building a layout in our vacation place and I wanted to know if others paint the cork roadbed prior to putting down ballast, or just paint the cork and leave it as is? My home layout I put down the cork and after years of resistance, I’m adding ballast to the tracks. It’s not my forte’, and Im not a fan of this task. I have some friends come over that enjoy doing this.
Hi Neal: If the track is already down, then I wouldn’t bother (I didn’t do mine, but I wish I had). If the track is not down, painting the cork either a color that generally matches your ballast or another dark color, will give the layout a more finished look, and will improve the look of turnouts, where you will only ballast minimally and carefully. Of course, if you plan on weathering the track and ties, you could expand that effort to fully paint the cork too. Joel
Maybe under the points it makes sense, but I did that, then decided to go with a lighter colored balast. Everywhere else it’s going to be sealed by whatever you use to glue your ballast with.
If you sand off the sharp corners on the outside edge, you will be much less likely to see any cork and you will actually use less ballast.
Interesting question Neal asks. I’m nearing the cork stage and hadn’t thought about the color. The additional issue that was raised above concerning painting it too dark and later using a lighter ballast needs some thought also.
So, any comments on color of paint selected would be a welcome addition to the thread.
I have sprayed my Homasote overall with Krylon Camaflouge Brown simply so that any small area that lacks scenery in the future will have sort of an earthy color rather than Homasote grey. I wonder if that color would be good for the cork? I weather my ties and rails with Modelflex Rail Brown.
Doesn’t matter what I use as roadbed, I always paint it so it has about the same color as the ballast. Closes the pores of the roadbed so the glue doesn’t get sucked up and hides the roadbed if there’s a hole in the ballast somewhere.
Huh, I never even thought about this before. They sell Granite Fleck Paints in a rattle can in quite a few color variations. I can imagine cork might look really good coated with this product under the track, in between the time you finally get to the painstaking step of ballasting. Well you definitely got my cogs turning here[:|]
I didn’t and wish I had. Go darker than what your ballast will be and you won’t notice if you get a bald spot. Going lighter the bald spot will rear its ugly head.
It is the same with landscaping in general on the layout, start with a lack of colour or go as dark as you can.
After the fact,[:S] I started watching some modeling experts on FB, You-Tube and some other sites including a few movie industry model makers and this was the one thing they seem to agree on. Start dark and work towards the light.
I’ve heard of people using “stone” flecked type paint, but never seen it.
I lay my cork, using caulk to stick it down. Sand it smooth. Do not skip this step. It makes a much nicer track laying experience.
I then paint the cork with craft type paint a gray close to my ballast color.
Finally put down the track using a thin coat of gray caulk. Makes it look acceptable to my eye until I’m happy with it and start to ballast. Puts the ballasting off for a while.
Because if you miss a spot while ballasting, it will not be as noticable than if it is a bright color like cork. I use foam because of the weather here would destroy cork within the year, and if a hurricane were to hit, the entire trackbed would be destroyed!!! [(-D] ( I bring this up because foam is generally black so it would not need to be painted)
My roadbed, Midwest cork in most places, gets painted when I paint the track after it has been installed, feeders wired and checked for gauge and smooth operation and install the “missing” ties at the track joints.
Then everything gets light coats of various primers and the Camo-Earth brown making sure I have the sides of the rail covered. Then I use a very light dusting of gray, from straight above as to avoid getting any on the sides of the rail, in random places. This takes the “edge” off and gives the look of Sun bleaching just a bit.
Once the paint has dried to the touch but before it has completely cured I clean off the tops of the rails with a felt pad and a little naptha (Zippo lighter fluid) then buff the rail heads a little more.
Then the ballasting process can begin. Personally, I enjoy ballasting very much. This is the stage when the trackwork “comes alive”.
Below I have the ballast spread but not glued yet. Less ballast is much preferable than too much.
Fleck paint from a rattle can is thick and hard to work with. It doesn’t scrape off easily, and stinks way worse than regular rattle can paint, IMO. I’d avoid it.
Brush painting with regular house paint would be the easiest and less messy way to go.
I got some used cork that was destined for the dumpster when a nearby club tore out their layout, and it was painted (likely because nobody there enjoyed ballasting). It was still useable, but it seems to me to be a waste of time, money, and effort if you plan on adding ballast later.
Personally, I find ballasting not onerous at all, and it and painting rails are the two model railroading tasks that will give you the most bang for your buck.
Those tasks alone, once done, can elevate a trainset to layout status, in my opinion. Scenery and nicer trains are just window dressing after that.
Except for experimenting with flecked spray paint on the roadbed under turnouts (an experiment I did not repeat) I have never painted my cork roadbed. Never felt the need.
I have painted homasote subroadbed (also shellacked it) as per articles in Model Railroader about controlling expansion and contraction and warping of homasote and will say this: first, painting/shellacking, while it “works,” essentially comes at the cost of homasote’s sound-deadening qualities and suspect the same is true for cork roadbed. Second, shellacking and/or painting homasote makes it much less easy to drive a brad or spike or pin into homasote using just your fingers or a pliers (which is one of the nice features of working with homasote), and again, I suspect the same is true of painting cork roadbed.
I didn’t on the 1st layout and not sure about doing it on the 2nd. It never was a thought until you mention it. Do I need to lift up track to pain or am I ok after the track is down but before ballasting? How many coats are sufficient?
Thanks to all who replied. My first layout here in NJ I didn’t paint and I’m doing ballast along with some help. At my vacation place, more than likely I’ll paint the ballast. Maybe, down the road, if I can find some volunteers to help, I will ballast the tracks.
One thing I saw is that someone mentioned sanding the esge of the cork to give it a better look. I like that idea.
Any volunteers for South Florida? Food included and I’m a mean grillmaster, LOL!
