do you run lighted passenger cars? Any problems with reverse loops or insufrog turnouts?
Probably over a hundred of them [Y] ! It is one of the major benefits (for me) of DCC so that I can see interior lights on even when the train is stopped. Other effects, such as EOT devices and marker lamps and Mars lights on the rear of a train are an added bonus.
No problems over frogs and the only caution for reverse loops is to keep in mind that the train can not bridge the entrance gaps at the same time as it is passing the exit gaps. Longer passenger cars with pick-ups on the wheels will act as conductors (not brakemen?) so you have to be sure your train is shorter than the reversing section.
Many of my cars have capacitor “anti-flicker” circuits and it is possible that the resetting of a breaker or the start-up current may tax the DCC system and you should have adequate wiring and amperage capacity to handle that OK.
Good Luck, Ed
I have two trains worth. They do not cause problems.
I suppose I should include the subway trains, too. Make that four trains worth.
+1 to what gmpullman said.
Just make sure your passenger train is shorter than your block, and everything should be okay.
