We currently use a sound system which is not integrated with the layout, but eventually, the speakers will be mounted in the benchwork, with racks to hold the equipment suspended underneath.
There are two seperate sound systems, each with two speakers, for a total of four. One is an MRC City/Country sound system with speakers, and it is self contained, not electrically connected to the other sound system or to the layout. The samples in this unit are of relatively low quality, and it is only used for the church bell sample, and once in a great while, a dog’s bark, a cricket, or a rooster. All of these are short samples, triggered by a pushbutton on the unit’s control panel. The unit also has other triggered samples that aren’t very good, and some looped samples, triggered by an on-off switch, which are so short that the looping becomes obvious very quickly, and irritating shortly after that.
The other sound system is a bit more complex. We use a Radio Shack DJ mixer to combine sound from three seperate sources, a pair of MRC Synchro Sound units, diesel or steam (only one is in use at any given time), controlled by DPDT switches, a PC, and a seperate line in from the PC’s CD player.
The Synchro Sound units provide a basic background sound, which parallels throttle settings for the various locomotives in use. Occasionally we will use the horn/whistle triggers on the Synchro Sound units, but the samples there are not of very high quality. The coupler crash sample does a reasonably good job of mimicing the slack coming out of a long string of cars, it works well with momentum turned on at the throttle pack. The steam release is a good one, and works well for both diesels and steam engines.
The CD player is used to generate natural background sounds, using one of two CD’s we made here at home using samples obtained from the internet.
The daytime CD combines several forest bird samples and several stream/waterfall samples. From the main throttle, the maj
