Does anyone have a LENZ system?
I am debating a DCC system for my first system. After fishing on here for opinions I found out that there were as many opions on DCC as there were modelers on this site and they all had different opinions. I like the looks of the LENZ 100. It is more that powerful enough, and I like the 10 year warrenty. But I have a few questions I can’t seen to find on the internet.
  1. Can I use a computer to hook up to the system to program decoders? I know i can use the system but I have heard that the computer interface is easier.
  2. Does it have a fast clock display…it’s really not that big a deal…I just thought it was a neet item that some systems offer.
I have a small layout about 14X 16 and want to run atleast 3 locos at once. I want to use the system to throw some switches and maybe turn on some building lights. Also I want some sound in the future so I need power for that. I know there are cheeper systems out there, If you have the LENZ 100 or 90 system…Let me know what you think.
Pat Taylor
I just bought a Lenz 100 this week. I wired it up directly from the instruction manual’s first few pages. After also wiring my first decoder (a Digitrax DH123D) I turned the system on and it worked perfectly. The manual is very clear and gives good step-by-step, keystroke-by-keystroke directions.
The Lenz 100 interfaces to a computer via the LI100F interface box. That’s an add-on that would have to be purchased separately. I don’t have one, so I can’t say much more about it.
The Lenz 100 has separate programming track outputs. To program certain functions, in particular the locomotive address, you need to have a programming track. Again, wiring instructions are very clear, and they also include the schematic for wiring the programming track with a DPDT switch so you can use a siding on your layout.
The system requires an external power supply, nominally 14-16 volts AC. I’m actually using an ancient Lionel train transformer that probably dates back to at least the Korean War. It works just fine. It may run out of power at some time, or maybe Lionel so over-designed it that it will handle anything.
I didn’t see anything in the manual about a clock display of any kind. I might have missed it in my hurry to turn it on and run trains, though.
I did some research myself before I bought this one. I decided I wanted a 5-amp system to support expansion, lighted passenger cars, etc. I also wanted a system which can control lots of functions. (I think the Lenz 100 is 12, but don’t quote me.) It supports back EMF, which is a nice feature, although I’m not using it now. It also supports 4-digit addressing, and has a 256-locomotive memory stack.
I use the Compact - works well though it’s a little limited. The general build quality and ease of use is excellent - I was able to get mine running within 30mins. Hope this helps!
I’ve got the whole sheebang!! Set 100 with LH90 Cab and a Compact, all have performed flawlessly. I recently got the computer interface ( serial port ) you still need a programme track. I use decoder pro.
Doesn’t have a fast clock, but haven’t needed it yet.
The LH90 cab is easier to use than the 100, it has a knob throttle and 3 pos switch for direction, the 100 cab is better for programming.
Any questions don’t hesitate to ask!!
Ken.
I purchased the Lenz 100 system, and shortly afterwards purchased a series 90 throttle controller as well. I have used several DCC systems and I am more happy with the Lenz system than any other that I have used. I program using the 100 controller which requires a programming track, and about 20 seconds of time. The commands are simple, and easy to memorize for your “next” engine to program. The system does require a separate AC power supply, I purchased a 16 volt 5 amp supply. With double headers… I sometimes have over 10 engines running at the same time. The system has been flawless. Wonderful construction. As mentioned by NZRmac, the 90 series throttle is a nice addition. It will retain 8 addresses that you can scroll through to choose your most used engines. It is best for switching operations. The big knob and the toggle switch make it a natural. I have not used a computer to interface to my system, it is so easy to use, why complicate it.
