Lookin’ good so far. I did something similar when building my layout. I took scraps of 1" foam board and used it as a skeleton for my hill. I then filled it with Great Stuff foam.
I would suggest making a web of cardboard since it is easier to change it. Basically you just take 1" wide strips of cardboard and glue down some initial strips going one direction. Then you would weave the other strips into it forming a web. You would then cover it with plaster cloth. However, newspaper works as well, you just need quite a bit.
Thanks LV, since that photo today I have added a lot more foam supports, reshaped the mountain and sides. This exactly how my son and I built that W/S learning kit. I have mounds of newspapers and bought a huge box of plaster cloth they use on real casts.
I have seen a video of the method you mentioned.
What I’m doing is making a list as I go along as to what would have been a better way to do things so when I do my next layout i’ll be even better. I really am learning quite a bit. Like I was told when I first came here, just do it, make mistakes and learn from them.
Paul, when you place those W/S cast portals, either show solid rock above the capping or cut the slope to drop just behind the capping. From the base shape it appears that the flat foam will show well above the portal. If you need additional distance to contour the hill downward to the portal top, move them out away from the “mountain”
Solid rock above portal (do leave space for the castings to still be behind the cast capping)
Portal similar to your placement (hillside contour slopes down behind capping)
Not sure what is planned up to the base of the “mountain”, allow the hill to slope down and out onto the curve. This can be done w/ foam or cardboard strips.
For future reference, it always a learning curve, constructing mountains of terraced extruded foam or cardboard lattice works easier and allows better flexibility of contour.
Keeping the portal slightly away from the backdrop allows to place the wing retaining wall and still have a touch of scenery (so casting isn’t just planted flat on wall)
Bob, thanks for your advice and photos. I’m a little unclear by what you mean though. In my photo the portals that are in place now are just foam. I plan on securing them to that foam with abutments too.
As for the backdrop and it being so close, well I really have no choice because the tracks are so close to the edge of the table.
If you can reach in both ends to clean the track, then will be OK. However, once you mount the portals, it may restrict your reach into the tunnel. I’d check that before gluing down the portals. My tunnels are single track – and narrowgauge to boot – so I made my portals so that they are removable to allow me to get my hand inside.
In fact, seeing how the moutain sits on the edge of the layout, you can cut access holes on the table edge side of the moutain to get more access to the track in the event of a derailment.
Sorry, but the answer is “Wrong.” Remember, if anything can go wrong, it will. You may have a kink in the track that causes frequent derailments that eventually will drive you nuts. The track may come loose for some reason. Or…
I have subways. I run both NYC-style trains and trolleys in the tunnels beneath my layout. One day, a trolley stopped dead and shorted. I removed one of the liftoffs I’d carefully built and removed the trolley. That is, I removed most of the trolley, all but one of the wheels. It was nowhere to be found. I searched the easy spots, and then I used the onboard camera to look where it was hard to see directly. Nothing. Finally, I removed the final liftoff, the one I never take off because it’s got a lot of wires going to it, and there was the wheel, a good 6 feet from where the trolley had come to rest.
Well, if anything goes wrong I’ll have to deal with it. It’s a little late now to change it as the tunnel is made from W/S tunnel formers covered in plaster cloth. You’d need a chainsaw to cut through that thing.
It’s a risk I’ll have to take. Besides, this is only my first layout. Basically an exercice in learning.
The right hand vertical foam looks to be the portal height and will work to bring scenery down to the portal cap. The left side however has that vertical foam much higher. Place the portal against the foam and you will see that sheer vertical section protruding above the portal cap. The cap is only about 5/8" wide. This won’t allow enough space to place scenery/ rock castings or added cut foam rocks w/o sinking the portal into the mountain. I would suggest building out the portal at least 1-2" to allow for this. Unless the prototype portal was placed/ built directly against a "solid’ cut of stone, any loose rocks will fall on the tracks instead of behind the capping. You could easily cut a “horseshoe” of 1’ foam and furr out the portal casting. This will also help when dropping the contours down into the corner @ the “wing/ retaining” wall. Hope this helps.
Also before installing those portals, you can modify the foam to add a tunnel liners. This only needs to be a short facade could be a piece of foam carved to rock and painted dark to match. You can see these done in some of my pics. One is even a painted carved pine block.
Hi Bob, after a nap today, (I stayed up late last night) I slept on it and it hit me! Bingo! You’re right, it looks stupid! I can easily remove the “brace” on top of that portal support and it will be more like the other one. After that it’s easy-peasy. Newspapers and plastercloth and voila, mountain.
I completely understand now and I really appreciate the advice and photos. I would have put plaster cloth on it and noticed too late. LOL!
Now your cookin’ running on all 8 cylinders. Been there too many times to count myself. When I will screw up- it will always be a dandy. Cut that piece 3 times and it was still too short!
Do check out all your clearances before permanantly attaching those portals.
Oh yeah, regarding those portals. Well I used a hot wire foam cutter to cut them out using the hydrocal casted one as a template. Then I put it against the wall and ran two side-by-side trains with the longest rolling stock and they clear both sides. Not a problem.
