Doghouse policy
Thank You, Sir.
I was NOT aware that N&W or that ANY road applied Doghouses to Psgr. Steam. A travesty to be sure.
I always considered the N&W to be a classy road, and the Virginian and its electrics. The way things should be done.
All comments in these Forums are generalizations from personal experiences.
Near the end of steam, my Employer kept it’s steam power up, esp on Passenger, as it was part of the whole ‘Image’ thing, esp when hauling Share Holders out of Windsor Station, Montreal.
( This all went out the window once Action Red took over and the penny pinchers discovered a dirty locomotive would pull as much as a shiny one, and paint and wiping cost money. The other joke was why did the Co. switch to Yellow Cabooses. Answer, Red paint cost more. )
However, the next door neighbour looked like junk, as if they had robbed the scrap line for power that had a few more miles in it.
Just 'cause Road A did something outside the front door, does NOT mean another road, 800 miles away did likewise. WM was always spotless, even their Baldwins. The 244 Cabs were glossy as the day they left Schenectady, and the BL2 and Slug on the Hump a marvel. There I saw my first Electric Eye which triggered a pump to squirt Journal Oil into Journal Boxes w/lid open, the shine reflected from Axle end triggering the Eye and pump.
More interesting than the BL2 after it had been digested. ( Traitor ) It did arrive at the pump, slowly for the Pin Puller and Retarders beyond.
The way a Diesel SHOULD look, late in it’s life. NO MU. Which would help it stay clean, as rarely trailing unless behind another Unit w/crew.
http://www.trainweb.org/oldtimetrains/photos/cpr_diesel/8403.jpg
Another story.
Was at a level crossing at night and the fellow beside me,
Funny you should mention the oiler! This one is at the hump in Gateway yard on the P&LE!
OK, now back to doghouses.
Regards, Ed
Thank You!! So much has changed. Iron shoes, gone, too, and their smoking wheels on heavy grades from Journal Oil drooling down the faces.
One of the nicest First Gen sounds was 5 567s droning downgrade in D/B holding her back.
Once the Diesels Came, Corporate and Union Policies changed, it now often seemed the FIREMAN was in the Doghouse, even in a Diesel Locomotive Cab.
Awful time to be there.
I was.
Sorry.
Off Topic, But, Steam.
I am partial to Compound Articulated ( Mallet ) locomotives. Fascinating, and Complex.
Many a word has been penned regarding same and many a photo published.
Many Railfans LIKE the unusual and get joy in finding the oddities out there.
Here is one way to change an eight-wheel tender into a twelve-wheel tender on the same locomotive.
With 8-wheel Tender.
http://www.rrpicturearchives.net/showPicture.aspx?id=3674500
And with 12-wheel tender.
http://www.american-rails.com/images/CBDMD7212.jpg
Thank You!
If I am in The Doghouse, too, move it to a New Thread
I was under the impression that doghouses weren’t applied to N&W J’s until those engines were withdrawn from passenger sevice and used on freight trains. Yes, a travesty.
After they were removed from passenger service, N&W J’s had doghouses and often an additional “water bottle” auxilliary tender added so they could continue being usefull as freight engines. The alternative would have been to scrap them right away. This way, they got a couple more year’s worth of work out them - and possibly, that extra time lead to 611 lasting long enough to be saved for later restoration. Hardly a “travesty” IMHO.
An aesthetic tragedy. Preservatiion of the only surviving J is a success story — not a travesty.
Yes,and a lot of the firemen I worked with on the PRR was considered “fixture” firemen because they was qualified engineers but, they held the left seat because of seniority and pay rate as a senior fireman.
