Much, much, much and very much more has been said about floodwaters as the cause of Doon/BNSF derailment. Did I miss something? Is it possible the cause could be hotbox or broken rail? Has this possibility been ruled out?
A crew I carried were relieved after an axle melted, causing HOS issues that took them out of service. They passed a hotbox detector with no fault reported. In the darkness they SAW the problem and rather than dump air (headend was in the middle of a small city) and they didn’t want a pile up. Slowly they got the train stopped and got chewed out for so much damage to ties. They had no derailment as he did not allow slack. Darned if you do, darned if you don’t. NEXT detector was just ahead and almost got taken out by bad order car.
I ask the question and gave the example, in that it shows how quickly a hotbox can occur, even when detector gave all clear mike endmrw0709181726sa
It’s been mentioned by several people. Or at least the possibility of some sort of mechanical failure. There was a derailment (also involving a key train which struck a derailed car) a few years ago caused by a broken axle, as I recall.
One thing that assists in causing a derailment when a hot journal is detected is using the air brakes to stop the train. Freight car brakes apply the shoe at a single point as the circumference of the wheel passes it. When the axle is hot the brake shoe pressure pressure can move the wheel out of line of the near molten axle - thus ending up with a ‘wrung journal’.
… best I recall (the incident mentioned in my post) the end of the wheel set (journal/bearing area)… was missing …as in GONE …awesome sight to behold
… … tree: reference the UPS/UP on ground in AZ…similar sight of some derailment recently (within last couple of months)and mentioned on this discussion board…since you inquired of the most recent derail…do you recall the one in the northern midwest recently and the cause of it ?..I might be mistaken but it seems the one I am inquiring about was a… “rail runner”…OTR van w/wheel set attached…big mess and I am too lazy to go look back over past threads to see if there is a follow-up
…hopefully it will have a thread name that sounds familiar … the naming of this thread I started should get heads a turning …mike endmrw0711181723sa for those keeping count…this post was typed with 4 paragraphs double spaced
Many years ago, when I was a conductor, our train got hit by a hot box detector. We were about the third or fourth train to get hit. Since the detector hadn’t been taken out of service we still had to inspect. The engineer had brought the train to a stop, I got off, and he pulled the indicated car up to me. (That was, and still is allowed when operating on wood ties.) The indicated axle was OK, so I started back to inspect the 20 axles behind first. Two cars back I bent over to apply the tempstik to the bearing. I didn’t need to check the temperature of the bearing, it was gone. When the train started moving, it had seized up and had twisted off. The truck side frame had been dragging over recently installed wood ties for about half a mile. (Later inspection said they were OK.) They sent a wheel truck out and replaced the wheelset. I saw most of this operation until the relief crew showed up, as we were about dead on our HOS.
I never heard anymore about the incident. The bearing was left laying in the weeds for about 10+ years. I always looked for it when I went that way.
Bolster story: Ed, SSW 8389, and myself have done field research on the abandoned Cotton Belt, Birds Point branch line.
He and I have a farmer friend who we check with often. The branch ran almost at his back door, for sure it is the boundry of his back yard.
Last trip up there he asked us to look at something. Keep in mind that this is the I-57 area crosssing the Mississippi. But a state highway crosses from Cairo to the interstate and has commercial traffic (maybe a short cut?)
He found 4 that is …four bolsters on the side of the highway by his mailbox. He knew they were RR stuff and got someone to ask UP at Dexter. Nobody knows anything. Before he got them drug to his front yard, someone had gotten one of them.
You know how heavy they are. I don’t think some guy and his girlfriend picked the one up and
I called a local news outlet in Doon about 4 days ago and asked if they knew the cause of the derailment. They said they did not because no official cause has been announced by BNSF or any other authorities. They did say that they have been told by the people doing the investigation that the cause will be made public as soon as they find it, but so far, they have not found the cause. It is not much information, except for the stated intention of publically announcing the cause as soon as it is found.
The line didn’t stay closed too long. On Saturday the 14th I caught two trains, one coming off the line the other going onto the line at Garretson, S.D. The northbound was all tankers.
Doon is a town of less than 1000 people. The “local news outlet” is likely the clerk at the Casey’s convenience store repeating what the customers purchasing coffee have said.
Unless forced to do so by a lawsuit, I have doubts that BNSF will ever release any detailed analysis of what occured. Many of the small towns in the area reported 5 to 8 inches of rain the night of the derailment. I suspect any analysis of the wreck will involve inadequate response to conditions somewhere within BNSF.
When I searched for “Doon newspaper” I got an area radio station’s website and someone’s FB page, which looked like what it probably is - someone thinking they’re a news source. The images didn’t look like those you’d see on a reputable news site.
So now I am supposed to be repsonsible for the credibility of the news source? At least somebody picked up the phone and seemed to have talked to authorities about the wreck. It hardly matters because they had no information other than they have been told that the cause of the derailment will be made public. But I have no idea if that will be the case. If anyone here has got a good reliable Doon news source feel free to call them and ask the same question. I suspect there are people in Doon who know what caused the derailment. Because people on the ground during the cleanup may have found the cause with convincing clarity.
This is a service of KIWA radio (as I think someone mentioned) out of Rock Rapids, which is about 7 miles from Doon.
I think the telephone number is related to their advertising department, which might not be a direct source for ‘information’ but they could almost certainly put you through to the person who coordinates the daily news report you can hear streamed/stored on the Web site provided. I would be tempted to ask questions (politely, please) on the associated newstips@lyoncountydailynews.com site (the link as listed on the page is corrupted)
Note that train wrecks are not the ‘normal’ sort of community news this service provides, but I think you could stir up enough interest to get boots on the ground.
Where are the pictures of the Queen of the Fair and runner-up?
The meal they’re serving sounds pretty good.
I was not expecting to find out how ‘spotted dick’ pudding got its name on a service of this kind in this location. But there it was.
Oh I think that is pretty far fetched. So you must think I was trying to pull the wool over your eyes by quoting from what you regard as a non-credible source. They said they have no information. Maybe they really have been informed by authorities that the flood caused the wreck, but they are so non-credible that they forgot that they were informed. How do you determine that the source in Doon is not a credible information source? How do you determine that any news source is credible or not credible? Personally I would not “expect the same from anyone else”, as you say. I consume news, and judge whether I think it is credible. It would never occur to me that it should be independently certified to be credible in order to protect me from incorrect news.
