Double crossover switch
I’d like to know what combination of LBG switches and cross track can be used to create a double crossover.
I am not sure what you mean by “double crossover”? There are TWO configurations that fit your description. The first is normally referred to as a “scissors with diamond” and the other a “double crossing”.
Have a look here and then let us know which of them you mean.
http://www.cabbagepatchrailway.co.uk/mls/g3/pointwork2.pdf
regards
ralph
I have done this using Aristo Stainless Steel: 1 19deg crossover, 2 left and 2 right #6 switchs, and 2 - 24inch sections of thrack cut down to 19.5 inchs. Hope this helps. Looks nice, worked well but took up about 7.5 foot of space.
Dave
It can be done but requires a very small bit of track cutting. LGB never created a crossover to do this easily with their 22.5 or 15 degree curved switch radii. My guess is a double crossover arrangement was not popular in European railroading.
Use two LGB #18050 (RH large radius switch) plus two LGB #18150 (LH large radius switch).
Connect switches’ straight with 2 LGB #1000 300mm straight sections.
Use LGB #13000 30 degree crossover. The crossover, unfortunately, is made with one branch slightly longer than the other. The geometry of the #13000 was made to work with LGB 2 ft radius switches (1200 series) in a multi track station crossover arrangement quite different than what you want.
The #13000 crossover fits almost perfectly between all four switches except for having to cut a few mm off each end of the longer branch. See red circles in attached diagram.
Photobucket
Excellent sketch on gbbari’s LGB solution. Just wondering what the main line track center to center spacing turns out to be? I need 6"for it to fit on a double track bridge.
ed65 - Welcome to trains.com! [C):-)]
I believe it is well over 6 inches centerline to centerline. You could scale it off my drawing since that was done using RR-Track software. The track gauge is roughly 1.75 inches wide, so use tht as your baseline. Or if you’re willing to wait, I can throw one together this weekend and measure it. I have all the necessary components.
I did not know any railroad that would put a crossover on a bridge. Is it absolutely necessary to place it there in you layout? I recommend taking a serious look at alternatives.
On the other hand, if it absolutely has to go on a bridge, LGB components won’t work because the centerline spacing will always exceed 6 inches. I would use the largest number switch you can afford. A 19 degree crossing would require 9-1/2 degree turnouts but I’d bet you will wind up cutting track to make it work…
