double heading
How many 40’ coal hoppers can I pull (realistically) before I should run two loco’s, SD40-2’s.
Thanks Ken.
From your signature, I thought you’d be asking about double headed steam. Hmmm.
Who makes the SD40-2? Do you have any grades? Many sharp curves? Empty hoppers?
On flat land, I say 35 loaded hoppers before straining.
Aggrojones
BLI makes the loco’s, 2.5% grades, 20ish" turns, HO, empty and full hoppers.
I kinda meant prototypically how many before they would MU?
Ken,
Aggrojones was right to ask because the prototype would be taking that all into account. They try to run exactly the amount of power they need. Otherwise it’s a waste of money for them. You might be able to answer your own question by going to www.railpictures.net and looking up a unit coal train pulled by SD40-2’s and counting the cars. Personally I’m interested in the nuber as well.
Jesse
for modeling purposes with selective compression I’d say any more than 15 cars and I double up, at least that’s the rule I use.
~METRO
I’ve been running 10-12 cars and one loco, I’m just starting on the coal mine yard, and wanted to put a loco run around track, so I may need room for two loco’s.
Ken.
weight of train and power says how many engines to use plus any grades.
Use the same concept for the model.
Or just doulble up anyways to make sure…
If a train couldnt make it up the hill, they would double up the train, take half the train up, come back for the rest.
oh the fun of operating…
Keep in mind a lot of the prototypes use multiple locos whether they need them or not for the pulling power, just so that a unit failure doesn’t disrupt traffic flow on the system. CSX has one old two loco lash up around here I don’t think they ever seperate, even on 9 car trains.
Too may variables (Multiple answer’s).
Weight of engine = weight of cars…
PLUS
truck friction (rolling)
empties vs ‘loads’
You basically add cars until the wheels slip.
Want to pull more cars? - Use freer rolling trucks.
Thanks everybody, I’ll make my run around track big enough for aleast two loco’s
Ken.
