Double main line on an L-Shape layout?
I am going to make a layout with an L-shape base. It will be 1 4x8 foot sheet of plywood, a 4x4 foot square on the side to make the tail for the “L.” I am going to connect both corners where the square and the rectangle meet.
going to be. I don’t know how much space i should leave in between the mainlines to keep them from
sideswiping/ derailing. I also run Athearn AC4400’s, SD60M’s, proto sd50’s etc.
Austin,
You could have just asked this same question,on the other thread,you started,rather than start another one…Less confusing that way,Instead of hitting,new post at top right,hit reply at bottom right…
Cheers, [D]
Frank
Austin,
[#welcome] To The Forums,Now if you read this post,look at the bottom right of this page,you will see,Reply,click on that and insert Your Msg and hit post on the left…
Cheers,[D]
Frank
Your Msg.
Sorry, couldnt resist.
Shame on you, CJW. [^o)]
Who done that?? Get that, Man’s name…[:o)]
Cheers,[D]
Frank
Frankie, I don’t have a full name, but he goes by CJW. Can you pull his file and run a background check? [(-D]
I wish the OP would have posted this on the other Thread he started,would have been less confusing…CJW,would probably have a field day,with one of Randy’s posts…[oops]Sorry,Randy,could not resist…[:D]
Cheers, [D]
Frankie
What are you trying to say about my posts?
And who says he hasn’t? [(-D]
Randy and Frank on the same forum.
Doesn’t seem possible.
One a veritable fount of information. [tup]
The other…well. [(-D]
P.S. Let’s see how Frank twists this to his own liking.
Rich,
Randy and I are, cousin’s in-law’s,the Lion also and I believe,the Lion,was also on,‘‘Basic Wiring Question’’,You know that infamous,Basic question,that is in the,‘‘To Be Continued’’ Thread…[(-D]
Cheers,[D]
Frank
I misspoke earlier. I meant to say…
One is a fount of information, the other is a fount. [(-D][(-D][(-D]
Like in,‘‘Buckingham Fountain’’, Now that is Pretty at night.[angel]
Cheers,
Frank
