Double slip switch in HO
Do they make a double slip in HO??
YES Walthers #6 and #8. code 83 ,PECO code 100. Shinohara had code 70 and code 100. Look on E-bay.
Thanks!! Walthers says oct 25th is the ETA date for the new run.
Peco also do a double- and single-slip in code 75.
Single slip
Double slip
Jon
As previously answered, Peco makes an insulfrog double slip. I use mine with two Peco switch machines & two atlas switch switches (is that right?!). I went nuts trying to see which way the points were set by looking at them - I guess these old eyes cant see streight! I made little drawings & put them next to the switches. They work great once you figure out the wiring & direction! Lou.
Wow graet pics!! I would use PECO, as people here have said nothing but great things about their track, but I use cose 83. I will have to use the walthers ones when they come out.
Modelpower also used to make an excellent (for hidden locations) code 100 double slip – complete with attached and exposed switch motors – haven’t seen them at the LHS for a while.
