Holy necro topic, raised from the dead from 2006. Twenty lashes with a wet noodle Brian! [oX)]
Yes. Willy6 wrote an important post. Walthers makes a “modern” version of the same bridge.
No need to buy and modify the old one. Buy the new one.
Didn’t you ever learn anything from reading a history book ??
You can use a pouce wheel to add rivet detail, you can get one that provides pretty close to realistic spacing or use archer 3d decals of rivets
Some containers are a little taller than others. Don’t place two taller ones in the same stack and they might squeeze through. Or, you can shave off some material from the lower container and hope no one notices.
BTW, are those ‘standards gauges’ good for modern double stacks?
I can’t be certain if it is or not. This link says that the standard height for “modern” stuff is 2 11/32" or 59mm. If your standards guage is the “modern” version then I would think it would fit double stacks.
I have to say whoever had the idea for that standard guage cars is a genious!
