I have double track with current of traffic on my layout. I would like to install crossing flashers on a roadway using Circuitron products. I have Circuitron DT-2 Logic Grade Crossing Detectors and FL-2 Alternating Flasher actuators.The DT-2 uses a series of four “opti sensors” to detect train traffic,which then accuate the FL-2 flasher circuits.
My questions: Can I use two DT-2 crossing detectors to drive one FL-2 alternating crossing flasher that would power four LEDs in the crossing signals? This would be one DT-2 with four opti-sensors on the Eastward track and one DT-2 with four opti-sensors on the Westward track connected to one FL-2 flasher circuit. Thus, a train moving toward the crossing on the Eastward track would accuate the FL-2 through the DT-2 to cause the signals on both side of the crossing to start flashing. Would there be a problem with this setup if a train was also approaching the crossing on the Westward track? Would there be a problem with overlapping detction as trains approach the crossing on separate tracks in opposite directions? It seems to me that there should not be a problem, but…
Any advice will be appreciated.
Split Reduction
