Why do some coal trains have them & others do not?
OK - fair question - I will take a stab at it, since we use a lot of DPU’s here -
We have a fairly decent grade going south out of Lincoln. The ones going south usually have DPUs. The ones going east generally keep all their power on the head-end.
So must be the grades they are going to encounter in the trip.
It may also have to do with the weight (# of cars) of the train, and/or the track arrangement at the loading / unloading site.
Yes I understand about the grades. But, if you watch the Rochelle cam you NEVER see a BNSF coal train with DPUs but some of the UPRRs have them & others do not. The same goes for the tapes I have of the Kearney sub & Gibbons some have & some do not. I thought mabe the DPU is also needed at destination of the loaded coal train maybe the answer. Thanks for the reply [:o)][:D]
[quote]
Originally posted by Mookie
Consider, too, that if all the power is on the head end, the weight/stress on the first coupler is the entire train. With DPU, it is some fraction of that.
Thanks that is more what I thought it was for use when unloading probably when the plant does not have a loop track. [:D][:p]
[quote]
Originally posted by zardoz
I love the DPU concept. At first I was a little intimidated by it. But after running 2 coal trains and one grain train, I got comfortable to it. I make that rear unit earn it’s money.
Makes for smooth ride over hills, curves and undelations. [tup][tup]
It’s the train tonnage and the grade.
If the tonnage is too high and/or the grade too steep, you will exceed the knuckle strength if you put all the locos up front.
The “back of the envelope” calculation is:
20#/trailing ton/%of grade
Figure about 400,000# max allowable drawbar pull for a unit coal train.
So, if you have a 2% grade and a 10,000 ton train, you’re tractive effort needed to get up the hill would be 20 x 10,000 x 2 = 400,000# . Any steeper grade or heavier train would require distributed power.
We deliver unit coal trains to a power plant at Marshalltown, Iowa and to the CRANDIC (CIC) at Cedar Rapids, Iowa. They run these trains DPU, one on the front, one on the rear.
At Marshalltown, usual practice has been to unlink the DPU system, set the head engine over onto a yard track and have the engineer go to the rear unit and then shove the train into the power plant tracks.
At Cedar Rapids, they pull down to the CIC switch, use the head engine to pull in about 30 cars, cut off and run around and back to the train, pull in another cut and go back. Since this yard only has three tracks, the lead engine is placed on the UP main beyond and clear of the CIC switch. The system is unlinked, engineer is taken to the back engine and the remainder of the train is shoved into the interchange track. Cut off, grab the engine on the main and head back for Beverly yard.
If you happen to read Railway Age magazine, there was an article about the CIC recently that mentions a new connection between the UP and CIC. It’s been talked of for years. They finally built it, two tracks with concrete ties, able to take entire coal or grain trains intact into it with room at either end to take power off and run back thru on the other track.
It’s been ready to use for a few months now. So far all it’s been used for is storing UP trains. The UP and CIC haven’t come to agreement about using it. I’ve heard differing reasons as to why, but all it means is interchanging trains the old fashioned way.
Jeff
PS Trains may be left in conventional (all power up front) because the train could be going intact/run thru to a foreign line where the crews aren’t DPU qualified.
OK thanks but why do some coal trains have it & others do not? [:o)][:)]
[quote]
Originally posted by tflescher
OK so what you are saying if I understand correctly since all UPRR coal trains come from the same place shorter coal trains do not needed a DPU but longer coal trains require one is that correct[?][?]
[quote]
Originally posted by oltmannd
Thanks that is what I thought that the DPU was the loco used to deliver the coal. Also, thanks for the DPU qualified. [:I][:p]
[quote]
Originally posted by jeffhergert
[quote]
Depends where’s they’re going, too. The ruling grade anywhere along the route would govern.
Also, most unit trains are equipped with high strength draw gear, but much of the older equipment is not and is only good for ~250,000# drawbar pull. So, it could be an equipment issue, too. (not likely with UP Powder River coal)
But, in general, it’s grade and tonnage that rules.
Iron ore trains seen here at Eola yard on BNSF in Aurora, IL recently will have two up front and one DPU in the rear. These run over the C&I into Eola and tie up for about half an hour or so until the head end crew is run back to the DPU unit and then take the train to Galesburg using the single DPU unit as the control cab. Interesting hey?
spbed,
Keep watching, and I swear you will see EB taconite trains going through Rochelle DP’d. We started running them about a month or 2 ago. WB’ers will have all power on the front 99% of the time(empties of course)
Shrek
Exactly right, and having the 2 units on the rear is driving the engineers mad!!![:D]
In the Blue Mountains of Oregon, it takes a little more ‘oomph’ to get a coal (or bulk train in general) rolling. Therefore, it usually takes 3 ACs on the head end with a DPU ‘Four Pack’ (4 Dupes) midtrain. One/Two with a single Dupe like they use out around North Platte and the ‘flat country’ just won’t cut it. Manifests operate on a 3X2 and a 4X2 plan. Less than 5600 tons = Conventional, 5600+ tons = 3X2 DPU, 7500+ tons = 4X2 DPU. You also have to take into account that the train (no matter the tonnage) is powered up to 2.5hptt; otherwise it’ll stall on the ‘Mountain’.
(1) UP’s coal does NOT all come from the same place.
(2) Just spent 3 days this week watching UP & BNSF dpu’s in Colorado Mountain Country running 2-C44-9’s up front, a C44-9 and a SD90 midtrain and one or two C44’s ond the back end and BNSF trackage rights trains doing the same with SD70Mac’s and GE C44’s (First and second generation power is long gone)
