Drawing track on styrofoam
I designed my layout in RTS 7. How do I replicate the computer layout on the blue or white styrofoam? (i.e. tools to use, books to consult, etc.) The styrofoam will serve as the sub-roadbed. I plan on attaching cork to the styrofoam after getting an idea of how the layout will look. Anyone have suggestions on going from the blueprint stage to the actual design?
If necessary, feel free to send me a PM with your email address, so I can send you the RTS 7 file.
TIA!
Lee
I have access to an architectural firm’s printer so I was able to print the file out in full size. You could probubly print it out at a local STAPLES or Kinko’s.
-tim
Print your layout design on graph paper. Draw grid lines on the foam - charcoal from an artist supply is good - pens & pencils dont write well on foam & markers can eat the foam. Now copy your plan square by square on the foam. I used this technique over 50 years ago to copy the CocoCola Santa on a piece of plywood for a Christmas decoration - my youngest son still puts it up in his yard every year!! My [2c]
You can set your zoom factor to 1. The click on “View”, select “Page Preview” from the pop up menu. This will show you what your layout will look like when printed. If you print it like this, it will be full size. I used this method to print templates for my turnouts. I then glued them into place with diluted white glue. I glued the turnout down on top of the template using latex caulk. Don’t put any under where the moving parts of the turnout, though. Once the turnouts were in place, I connected them with flex track.
Well, I just lay the track pieces out on the foam. I use large T-pins to hold it in place, and just build it and make it fit. Then when I am satisfied with a section, I mark the centerline of the track on the foam between the ties, about every fourth tie or so. Take the track up and draw in the center line. If you display your grid in the program then print it out, you can select several reference points to transfer to your layout so you can keep things straight and on track so to speak.
