My DT400/DCS100 has issues with the Tsunami decoder.
You can setup the decoder for functions 1 thru 12. Problem is every time I try and set this up I get doubled functions.
1 thru 4 are no issue. The problems start from 5 and up. If I put :
function 5 = dim
function 6 = water stop
function 7 = coupler
function 8 = mute
And put normal for functions group 2 and 3 exchange under advanced.
Functions will not work.
If I exchange group 2 and 3, I get 5,6,7 and 8 to operate. Problem is they now also respond to 9,10,11, and 12 also. I am at a loss to determine if the throttle or the DCS100 are at the source.
I don’t believe that’s true. I am not aware of any Digitrax product that supports above F-12. Do you have a reference link that describes that upgrade?
I just got my DCS-100 back from Digitrax with the new chip upgrade for $35.00. The upgrade takes your DCS-100 from eight (8) functions to twelve (12) functions only.
Possible, but does not answer my question. Before the upgrade what how did it handel the 4 additional functions: did nothing or did as I mentionned in post and sent out the same command on all F9 thru F12.
I see in Loconet monitor that I am sending F0 thru to F8. I’m also sending F9 thru to F12 but in a different packet format than seen with F0 thru F8.
As I mention in post I must swap group 2 (5,6,7,8) for group 3 (9,10,11,12) to get 5,6,7,8 to work. It makes no sense to me.
By the way , I’m doing these changes via DecoderPro
You are programing a sound decoder. The DCS-100 does not do “blast mode” programing, which is needed for sound decoders. (The Digitrax Zepher does blast mode, but not the DCS-100 or DB-150) Eventhough you are using Decoder Pro, you are programing your sound decoder through your Digitrax DCS-100. I would suggest you purchase a “Power Pacs” (I have one as I just got my first sound locomotive.) for your Digitrax system. I have a Digitrax Chief and use the Power Pacs with Decoder Pro.
Wrong… I have PowerPax (even thow it works perfectly without it)… that is not the issue at all. I’m trying to understand the difference between the swap group 2, 3 and the normal setting for CV 30 on this Backmann Tsunami. The original Tsunami’s I have also do the same thing. It is not a issue of unable to program at all.
Before you had the update done to your DCS100, how were the F9 thru 12 responding is what I would like to know. Mine respond but give the same sound as defined on F6 function, in my case that is the water stop.
Before the upgrade I did not try the functions above eight. I have one sound locomotive, Atlas MP15 and don’t do much function programing other than lights and bell.
I don’t use my DT400 for programing and don’t much care to use it in operating (too man buttons). I have older DT-100R and DT-300R throttles. Since I use Decoder Pro for programing my throtles are primarily for speed control, lights and bell. My DT-400R was not responding due to too many trips to the canyon (concrete basement floor.) I wanted it in service for operating sessions, so when I sent it to Digitrax for repair, I decided to get the DCS-100 upgraded at the same time. In fact I had started another post regarding the use for aditional functions.
Sorry, that I can not be of further assistance to you with your problem.
No current Digitrax throttle supports above F12, but the current DCS-100 and Zephyr command stations do. You can access them using the on screen throttle available in JMRI. I don’t have a link that describes it, but I have controled all of the functions on my Athearn Challenger using my PC and Digitrax Zephyr.
