I am probably doing something wrong. I am trying to weather some black plastic bridges. I had a pretty nice looking result by ‘brushing’ on colored chalf powder. Then, I sprayed a bit of Testor’s Dullcote from about 7-8 inches. After drying, it seems like the chalk is gone!
yeah, that happens… you have to “overweather” with the chalks to make up for the bit that is washed off by the dulcote OR don’t seal with dulcote and handle as little as possible (preferably not at all [;)])
One method I have used is to apply a wash down the model after chalking it to simulate the effects of rain – it blends the chalk/weathering nicely and I have found the chalk tends to stick fairly well after the wash dries. I have used straight isopropyl alcohol before and water with a drop of soap (to break the surface tension). Either way, if you don’t handle the model very much, you shouldn’t need to dullcote it.
One reason I like using powdered charcoal is it doesn’t disolve like the chalk does. Even on a dark building or car it works well to gray or dull any white lettering. Then I usually go back after sealing the charcoal in with dullcote and add chalk weathering but don’t seal it in. Unless it’s something you’re going to handle a lot, the chalk will stay on pretty much forever.
Try using a dilluted wash of acrylic paint, use a wedge sponge to take off most of the liquid, then apply the chaulk power before the wash dries. Put the chaulk on heavy, then use a light coat of dullcoat. I use this method on my rolling stock, and buildings. The dullcoat does dilute some of the chaulk, by using a wash before hand the chaulk has a base to stick to, instead of getting blowen off while appling the dullcoat by an air brush or spray can. I hope this helps.
