Dumb question
What is the difference between G scale and #1 scale?
Thanks,
Rich F.
“G scale” is a complicated subject. Here’s the scoop, in a nutshell: There are many different scales using the same gauge of track. The track is 45mm between the rails, and this gauge is called “No. 1 gauge”. Most LGB, some Bachmann, and a few others are 1:22.5 scale. These are mostly meant to represent narrow gauge trains, but the track scales out to about 3’6". Not a very common gauge in real life, but there were some prototype railroads that used that gauge. And for many folks, it’s “close enough” to 3-foot. Bachmann also makes 1:20.3 scale trains, which accurately represent 3-foot narrow gauge trains. Some other manufacturers also make trains in this scale. Aristo-craft and USA Trains use 1:29 scale to represent standard gauge trains. The track actually scales out a bit less than true standard gauge, but it’s pretty close. MTH makes trains at 1:32 scale, which is accurate for standard gauge. This is what is commonly referred to as “No. 1 scale”.
Thank you for your detailed explaination. I guess it wasn’t such a dumb question!
Rich F.
