This looks like an electric boxcab that was built sometime prior to WW2. The photo contributor says this is an Alco-GE P-2b boxcab built in 1930. It’s amazing this boxcab was kept in service for so long, and this photo was taken only a couple of years before Conrail. I assume this boxcab was originally built for either NYC or Pennsy?
These units were used exclusively for the NYC passenger service from Grand Central Terminal to Harmon where the locomotives where changed to (originally) steam or diesel road locomotives. They operated mostly from third rail but there is a small pantograph for getting through the gaps in GCT.
It does have the 2-C-C-2 wheel arrangement as the GG1. I am not into the Electrics but I admire their longevity. If only we could build most things to last as long.
Lack of investable capital to obtain new equipment generally results in antiques continuing to operate long after their need for replacement. NYC and Penn Central both lacked investable capital.
As for diesels, I’d count first generation EMD GP/SDs in the longevity category too, even though those still in service are used by shortlines and industrials, and many GP 7s and 9s were rebuilt in the 1970s by IC, ATSF and other roads… Some first gen GPs and SDs still have their original high-short hoods too though. Here in central Illinois, a shortline called the Illinois & Midland (former CI&M) has a 4 axle EMD called the RS1325, which looks like a cross between a SW long hood with a GP18-20 style short-hood cab. Only 2 were built in 1960s and are still used. It can be argued that 38/40-series locos and even Dash-2s have a lot of longevity too, even though some of these have been through upgrades or rebuilds too. Still, the 38 and 40-series is at or near it’s 4th decade of service, and I don’t see GP38-2s fading away from Class 1s like the SD40-2s are now. As for non EMDs, several shortlines still use Alco RS and Century-series locos that are just as old now as when that Alco-GE electric was in 1974.
The P2b electrics were originally built for Cleveland Union Terminal and ran off of overhead with conventional pantographs. When that operation was de-electrified in the 1950’s, the motors were rebuilt for third-rail pickup and transferred to the New York operations. They lasted as long as they did because it would have been prohibitively expensive to replace them in kind (custom design, short production run, etc.)
Weren’t they a ‘T’-class in one of those location or the other ? Or was that another locomotive ? I always thought they looked very classy in NYC’s ‘lightning stripe’ paint scheme.
They were contemporaries with the New Haven’s 2-C+C-2 units, one of which was borrowed by the PRR for the tests that led to the GG1 with the same wheel arrangement.
That’s quite the massive and heavy-looking frame for that comparatively little box-cab on top, isn’t it ?
The T-motors were B-B+B-B electrics that worked passenger trains in the New York terminal area only. One was fitted with footboards to serve as a switcher at Harmon.
First came the S motors. They were later augmented/replaced with T motors. Finally, they were joined by the Cleveland refugees (P motors). I believe an S or two have been saved and one T that I know of. I think all the P motors went to scrap. I saw them moving white-lined thru Selkirk in 1975 or there abouts.
There were also Q and R motors. The R motors operated in freight service on the West Side Freight line. Some of the R motors went to South Shore Line in the 1950’s. Also keep in mind the various tri-powers which also operated in the New York area.
Bummer [V] - they were classy machines. Do you know offhand where the S- and T-motors are preserved ? I would presume somewhere in the New York City area . . . . ? Thanks.
I think they are upstate somewhere west of Albany. An NRHS chapter owns (owned?) them. In the late 80s they were stored inside what was the D&H’s Colonie shop along with an Alco Mexican Northern (now at NH&I). I heard they were later moved to an old power plant building just west of Schenectady along the Mohawk River somewhere. Don’t know if that’s where they are now or not.
Thanks for the hint. With a little more time to research this, it seems that there are 3 S-motors preserved, per S. Berliner, III’s “NEW YORK CENTRAL (and HARLEM RIVER) RAILROAD BOXCAB Locomotives” at - http://home.att.net/~berliner-Ultrasonics/boxcabny.html - as follows:
1906 NYC S-2 #113 - National Museum of Transport, St. Louis, Missouri
"1906 NYC S-2 #115 (the last of her class, decorated as Penn Central #4715) -
I did a little reading on these last night in William D. Middleton’s When the Steam Railroads Electrified (Kalmbach Publishing Co., 1974 or so). They were the first with the 2-C+C-2 wheel arrangement, which led to the New Haven EP-3a that was borrowed for the PRR tests and in turn led to the GG1. 22 of them were built, and all went to New York City, except for 1 that was destroyed in a fire.
There are a couple of deep ironies lurking in the history of these ex-NYC P-2 electric locomotives, as follows:
The 22 P-2’s were developed and built for the New York Central by GE in 1929-1930 for CUT, albeit with only 1 traction motor per axle.
GE then peddled the design to the New Haven circa 1931, which adopted the basic articulated wheel arrangement layout for its 6 EP-3a’s, but with twin traction motors via ‘quill drive’ instead.
One or more of the NH EP-3a’s was then borrowed by the Pennsylvania RR circa 1933 for extensive testing at Claymont, Delaware, in comparison with other PRR electric locomotive designs. The result was the GG1 - also with twin traction motors per axle, via a quill drive - starting in 1934, and ultimately ending with 139 locomotives.
So the first irony is that it was a smallish NYC locomotive fleet of 22 units that led - just slightly indirectly, with only a single intermediary, the NH - to the development of its riv
