Just finished cleaning my track (Kato N scale Unitrack) manually and I noted that cleaning the turnouts was difficult at the guard rails. The guard rails were slightly higher than the rail. This made me wonder how a track cleaning car (any brand) could effectively clean the track wherever guardrails were involved since the cleaning pads cannot make contact with the track.
For those with track cleaning cars, do you need to manually clean these areas?
I use a CMX machine. It has a soft pad that seems to do a very good job on everything. I don’t notice stalling anywhere after I’ve cleaned my track. I do no extra hand cleanup after a couple of passes with the CMX, using lacquer thinner as my solvent.
Maybe it’s just N scale track. I’ve never noticed the guards being higher than the track in HO. I use Woodland Scenics Dust Monkeys but sometimes I still manually clean the track once in a while if I notice a certain area that is dirty and causing problems.
Judicious use of a mill file will address the issue of those too-high guard rails. It worked well on my layout to correct too-high frogs on some of my Atlas HO turnouts.
