We have note that if we take a small piece of steel and bend it many times that it will heat up and finally break. However if we do the same number of bends but just a few bends at a time the steel will not break unless doing a lot more bends. Although not often we have noted that there has been several derailments due to rail breaks under the rear part of the derailed train and not under leading locos that weigh more than most cars.
If the structure under a track has several adjaecent cross tie sags would the rail more likely break with the constant bends and returns ? It might be temperature sensors on rails at sags would provide answers ? Anyone know if research has been done ? Would this accelerate metal fatigue over say 2 - 500 axel trains ? Maybe at Pueblo ? A 1000 axel train certainly has a lot of bends of a track . Are we off base ?
When you bend a piece of steel to the point of it taking a permanent set, you have exceeded the elastic limits of the steel. When this happens, the steel will typically work harden and when stretched or compressed too much will start cracking. Rail and bridges are almost never loaded past their elastic limit in normal operation, but fatigue is thought to be caused by progression of micro-cracks from loading near the elastic limit (also known as the yield limit).
Bridges definitely have a limit on how many loads of varying weight they can carry - governed by fatigue as you surmise. It depends on their ‘history’. The formulas are pretty complex. Heavy unit trains are usually the worst, depending on the axle loading and spacing, and where you’re looking at in the bridge.
Track is much more complicated, but what Erik says is a good summary.
This discussion on bridge fatigue issues reminded me of when I was a contractor, developing software at an internationally known crane manufacturing company about 1982 or so. In particular, the program was for their ‘smaller’ line of overhead traveling cranes that ride on a set of rails maybe 40-50 feet off the ground with the operator in a cab on the travelling boom to which the motorized pully lifting equipment is attached. We’ve all seen pictures of such cranes at locomotive manufacturing and/or repair facilities that pick up an entire locomotive or heavy component and move it somewhere.
In particular, I was provided specs by the engineering department of how to create the program. The ‘user’ input to the program was data regarding the height, weight, and load limits of the rail system on which the crane was to travel. The distance between the rails (gauge) was critical as the further apart they are, the less load that can be picked up unless stronger bridge steel between the rails is used…up to a limit.
Of course, the most ‘major’ criteria in designing the crane, whether done via slide rule, calculators, or computers, is what’s the maximum weight to be picked up, how far apart are the rails, and how fast does it need to travel down the rails. The program would then calculate a range of values for steel thickness, length, trusses if needed, etc, and provide a materials requirement list for each quality of steel needed (tensile strength/hardness). The engineers would ‘price it out’ for each steel combination and ultimately get the crane built and installed for the customer.
One of the anecdotal stories the engineers told me was about a customer that had one of their cranes in their factory for over 50 years and wanted new one just like the old one for their new factory. Of course, there was nothing common between the cranes as steel quality/strengths had been improved, and there was nothing ’
One of the anecdotal stories the engineers told me was about a customer that had one of their cranes in their factory for over 50 years and wanted new one just like the old one for their new factory. Of course, there was nothing common between the cranes as steel quality/strengths had been improved, and there was nothing ‘common’ between dimensions, weights, etc between the old and new cranes. The new factory opened up with the new crane, and about 6 months later, the engineers were called to find out why the new crane had a very noticible ‘sag’ in the traveling boom. The engineers triple and quadruple checked their designs for the crane along with the weight/speed/height requirements from the customer and everything was more than sufficient for the 150% load carrying factor designed into the crane.
So, they travelled to the new factory to see what was going on. It turned out that like the old factory, they used the crane to pick up still red hot 5-10 ton metal castings and give it a couple of ‘shakes’ by releasing the hoist brake and then slamming it on before the casting hit the ground to shake loose any left over slag on the casting…just like they always did at the old factory for over 50 years!
The difference was that in the 1920s when the original crane was built, metalurgy technology was still very limited as was their knowledge of tensile strengths of steel, etc. Everything was done by slide rule calculations back then, too. So, back then, stuff was designed for a 200% overload factor, but as they didn’t know the limitations of the steel being used, it turned out that the cranes of that era really had close to a 300-400% overload capability!
In effect, the ‘shake’ technique created a very momentary apparent weight of well over 2-3 times of the casting being picked up. It’s comparable to a head on car accident wh
Tensile strength is the most important design component, but not the only one by far. It always enlightening to young engineers when they see that a structure they designed is OK for strength but they forgot to check for deflection (sag) . . . [#oops]
Railroad bridge design these days still uses the Cooper E-series loading system - a pair of 2-8-0s with tenders of various weights, followed by a continuous load of X thousand lbs. per linear foot. Plus, an alternative load of like 4 ea. 100,000 lb. closely spaced axles - think of a heavy-load flatcar, or the ends of 2 ballasted C-C locomotives close together (I know, that’s 6 axles, not 4, but it’s the same principle - still 400K lbs. along about 18 ft. of track, if I remember right). That, and a more sophisticated - and very complicated - approach to fatigue management. So the greater ‘robustness’ is designed in these days, instead of happening as an unintentional by-product of lack of detailed knowledge. Plus, earthquake resistance is now designed in as well.
Notably, almost all railroad bridges are simple-span designs, not continuous. That won’t mean much to those are are not structural engineers, but it kind of guarantees that some corners can’t be cut to save some steel or cost somewhere.
Back to the OP, simplifying things: It’s not the length - it’s the number of cycles compounded by the weight.
As PDN noted as well, it’s darn complicated. And “foundation” is more than rails and bridges. Dozens and dozens of things have an effect on track modulus.
Thinking about this - the idea that the length of the trains is a factor (as opposed to cycles and weight) would seem to imply that the track can “recover” between trains.
Reading the posts of our resident experts leads me to believe that’s not the case.
If you bend a paper clip a bunch of times, but stop before it breaks, lay it down for a while, then start bending it again, it’ll break at the same number of flexes as if you hadn’t stopped.
The number of times that you can bend a paper clip can vary a huge amount between bending within the elastic limit and bending while exceeding the elastic limit. The elastic limit is the point where bending beyond results in a permanent change in shape. Other than the contact surface of the rail, I don’t see anything in the track structure that will approach the elastic limit.
Keep in mind that “fatigue” usually applies to a wear-out mechanism for cyclic loading below the elastic limit. The theory is that such loading will generate micro-cracks that eventually lead to some cracks growing to the point that the piece fails.
As for the original question on length of trains causing problems, the most likely source of problems would be tractive forces from longer trains, with the worst case being an emergency braking application.
The dimensioning for fatigue aims on preventing this scenario by limiting the allowable stresses. How much depends on e.g. number of load cycles, tension or compression or alternating.
When ties loose their footing and don’t support the rails anymore the fatigue is accelerated. The stresses will most likely stay within the elastic limits but the higher maximal stresses will reduce the number of allowed load cycles.
Regards, Volker
That’s pretty much what my understanding is on fatigue, i.e. there is a cyclic stress limit, that if not exceeded, will allow for unlimited lifetime. This stress limit is below the yield stress for the material and how much below depends on the material.
From what I understand, the issue of fatigue first came up with railroad axles.
With regards to paperclips, being them to the point of causing a permanent change in shape will result in work hardening (won’t go into the gory details about dislocations) which generally makes the material more brittle and the increasing amount of work hardening from continual reshaping eventually leads to a brittle fracture.
Anyway, my first exposure to elastic limits and work hardening was from my E45 class at Cal on engineering materials, with Professor Parker being one the lecturers for the course. The course did not cover much material on fatigue, though did get into stress concentrations.
Railroads keep statistics about the number of ton miles that are operated over each track. MofW uses these figures as one of the factors to be used when it becomes necessary replace rail and/or ties on a particular line segment. Records are kept identifying what kind of rail was installed, when it was installed and any other pertinent information. Records are also kept on when track last had a surfacing gang go over it and records for tie replacement. Data is kept on virtually all aspects of tracks.
Which makes sense as rail wear is proportional to the gross tonnage. Improvements in rail steel and maintennance have more han doubled the gross tonnage that a rail can support before replacing, but those improvements were based on the meticulous records of traffic. I suspect the use of wheel impact detectors is also an important contributor to extension of rail life.
On a related note, Timken was boasting of getting a 10 to 20X improvement in bearing life from improvements in steel quality (fewer inclusions). The 4th edition of “The Railroad, What it is, what it does” had a comment that the inclusions in rail were a common starting point for fatigue cracks, reducingthe number of inclusions in rail steel is one of the reasons that rail is lasting longer.
I think you are right. From my point of view it is more a cost saving measure.
IIRC (it was more than 15 years ago) flash-butt welded rails have the same fatigue behavier as solid rail. Thermite welded rail has a higher risk of breaking at the weld because of the weld material differing from the rail material.
Regards, Volker
Flash-butt welds are stronger than the surrounding rail.
Field welds have a greater chance of failure due to the less controlled environment, the human element and metalurgy of the field charge and molds.
Regardless, both are a major step up and above joints, bolts and angle bars in economic return and effectiveness. Also true is if you fail to maintain any of the above, you are on an accellerated road to failure. Shortlines and branchlines prove this out time and again. Many a shortline failed and abandoned because they had their priorities screwed-up.
The long rail sticks described in the article reduce the number of plant welds, not the number of field welds.
Anyhiw, most production-gang rail relays (which account for the vast majority of new rail consumption) result from rail wear, rather than from fatigue-related issues. In addition to better metallurgy and improved steel quality, rail life has improved due to better rail lubrication, more and better rail grinding programs, and newer rail sections that have more steel in the head of the rail (which allows for more grinding cycles and / or wear before the head gets too thin to live with).
On the other hand, while fatigue-related defects in the rail don’t account for a large footage of rail replacement, they do have a major impact on operations: service interruptions, slow orders, short maintenance windows to replace the section of rail containing the defect, and occasionally a derailment. Pretty much all rail defects are fatigue related, but there are different kinds of fatigue - or at least, there are different kinds of stresses that cause fatigue. Heavy cars or poorly supported ties cause the rail to bend like a bridge beam - but these stresses are usually pretty low compared to the contact stresses at the head of the rail, which is where the most common defects begin. Those contact stresses are affected by car weight but even more so by things like the shape of the wheel and the rail (both of which change as the steel wears), lubrication, and the car’s suspension and steering.
Improvements that tend to reduce defects include cleaner steel for reduced crack initiation, but also better lubrication, wheel impact lo
