In the early part of the 20th century and up to the 1970s, several railroads used pure electric locomotives on electrified lines, which were by the 1970s abandoned or replaced with diesel electrics. Two of railroads that had electrified lines which weren’t located in the northeast were Milwaukee and Great Northern. Milwaukee in particular operated the Little Joe, an electric locomotive built by GE, originally built for the USSR back in the late 1940s and sequestered by the US government for use by domestic railroads. If either GN (part of BN after 1970) or Milwaukee didn’t abandon their electrified lines and the continued to use electrified wires, I wonder what types electric engines they would have purchased to replace their aging 1940’s vintage units? In the mid 1970s BN consider the idea of electrifying some of their routes as a response to the rising price of oil during the oil crisis. Did EMD or GE, at one time or another in the 1960s and later, toy with or propose designs for electric freight engines? If such a need arose they could have leveraged the components of their existing diesel designs, minus the prime mover, to run off electrified wire.
An interesting question and I think the answer is probably not. I suspect one of the reasons Milwaukee abandoned electrification was not so much that it was cheaper to run an all diesel operation but that the infrastructure was just plain worn out and even if the Milwaukee was rich enough to replace it, it wouldn’t do it like for like but would replace it with a modern 25Kv or 50Kv system. However that is not to say that a modern electric would not look like latest EMD or GE diesel with pantographs! However it would be more likely some sort of double cab unit would emerge.
Or like those Amtrak E60’s. IIRC several coal roads out west have electric loco’s similar to those Amtrak E60’s as well as second hand units from Mexico (build circa 1990?).
That was BCR’s Tumbler Ridge line. Seven GF6C’s were built by GMD to work that line. The mine has since closed, the catenary de-energized, and the locomotives scrapped.
One clue might be to look at the PRR. In 1959, they leased 66 E-44 from GE. As originally delivered the units used water-cooled ignitron rectifiers to convert the overhead AC into DC for the traction motors but the later units (E44a’s) had silicon rectifiers that were much more reliable. They might have looked at something that was an interim step between the E-44’s and the E-60’s.
While it’s likely that the GN and Milwaukee might have considered similar directions, I’d have to agree that the age of their infrastructures and the costs to maintain and upgrade them were probably a big part of the decision to go with diesels.
Actually the mine is open again, but trains are being pulled by diesels. At least one of the locomotives was saved, it is in the Prince George Railway and Forestry Museum.
I may be mistaken, but I am thinking that this particular model of electric was actually built, and was exported to Sweden. It was on trucks provided by the Swedish Railway. It was actually shown in a TRAINS magazine, which I am unable to find at this time… I am sure if I am mistaken, someone can provide correct info. Thanks!
I’m not an expert on the GM10B or GM6C (built at the same time, on C-C trucks), but I think you may have reversed what happened. They were both built (I photographed them both running in NJ in the late 1970s), but I dont think they went to Sweden. I think there were both scrapped here. They did have Swedish elements to them (at least that sounds familiar to me), and maybe even had parts built there.
The problem for Conrail was that PRR’s old electrification didn’t go far enough for it to make sense to invest hard to get capital in straight electrics. The failure of PRR to continue it’s electrification to at least Pittsburgh, or more realistically Conway did not help the cause one iota! In today’s economic world the electrics wouldn’t make sense unless they could run coast to coast over two or more of the big seven. (Such as NS Oak Island-Chicago/Kansas City, BNSF Chicago/ Kansas City-Los Angeles/Long Beach, for example.)
Another problem we are facing a shortage of generating capacity since it is almost impossible to build an electric generating facility. Never mind trying to build an atomic plant, it cannot be done any more. Coal fired plants are much too expensive to build and are obsolete before they open! The EPA has no policy in place to permit such facilities to be built free of the litigation threat from environmentalists, or other NIMBYs. Damming a river that isn’t already dammed somewhere else? fuhgetaboutit![B)][banghead]
The problem isn’t supply, it’s transmission capacity.
The electric power grid tends to lose significant power over distance. It is highly inefficient. Currently, generating capacity is far in excess of needs, but the system loses so much in transmission losses, and the grid is “full up.” Utilities confronted “congestion” and dispatching problems long before the railroads did.
The culprit?
High voltage AC power transmission.
A U.S. Department of Energy Symposium held August 3, 2001, “Analysis and Concepts to Address Electric Infrastructure Needs”, recommended general use of HVDC [High Voltage Direct Current] lines in the United States, as the conversion of existing HVAC [High Voltage Alternating Current] lines to DC would double the capacity of such systems in terms of use of existing ROW and reduced cross-section and that fact alone justified a review of existing HVAC systems as a way of meeting demand which has exceeded current transmission capacity in the United States.
Engineers at the symposium pointed out that not only could HVDC move substantially more power than a similar HVAC system, but that “for an AC line with the same conductor and insulators per phase, losses were 50% higher” than for the HVDC systems and the efficiency of HVDC systems meant power savings and a substantial reduction in current transmission losses.
There were two GM experimental engines tested. Both were white. I think the other was numbered 1977 or 1978 and had CC trucks. Neither was adequate for CR to pursue which doesn;t really surprise me since GM had never built anything like that before. GE was the master of motors as the PRRR called them.
Interesting-I always thought that DC was prone to losses that AC wasn’t (hence the Edison/Westinghouse battles of the currents 100 or so years ago). Any idea at what voltages the HVAC losses become greater then HVDC?
Back in the Edison-Westinghouse days, DC meant low-voltage DC, the voltage you got straight from the generator without step-up transformers.
High-voltage DC (HVDC) means you use transformers and electronic switches and rectifiers to step up the voltage and turn it into DC. HVDC has losses associated with those electronic switches. AC has losses associated with the voltage switching back and forth at the line frequency. Apart from those effects, the low loss is from the high voltage which means low current for a given amount of power.
I thought HVDC was lower loss because you could operate it at higher voltage given the technical restrictions on AC voltage.
