In the heyday of steam and before the time of the diesels, how did steam locomotives generate electricity for passenger trains? Where was the generator located?
Typically steam locomotives did not generate any electricity for passenger trains. Each car had an axle-driven generator to recharge its batteries, and in later days, package engine-generator sets (such as Waukesha) were applied to some cars.
Steam locomotives generated electricity only for their own electrical needs (lamps), using a steam-driven turbo-generator usually mounted on the boiler top.
RWM
Some of CNJ’s steam locomotives had a tender-mounted generator to provide power for lights on suburban coaches. Short runs and lots of stops probably would have caused excessive drains on batteries since axle-mounted generators couldn’t recharge them very well.
This was true of most commuter operations.
Steam era cars used steam for heat and for cooking in the diner, I believe there were even steam-powered air conditioning systems!! Until recent years passenger diesels included a steam boiler to generate steam for the passenger cars.
Slighly off topic but GG1s on the PRR had a steam generator to provide heat in Winter for any passenger consists they pulled.
Next time I see photos of CNJ steam locomotives, I’ll look for that generator on the tender. Where was it typically mounted?
That was Carrier’s steam ejector system. The basic idea was using a steam ejector to create a vacuum, and that vacuum caused water to boil at low temperatures (water boils at 45F with an absolute pressure of 0.14 psi). The cooled water would be circulated for cooling the car. The AT&SF was a big user of that system, though the steam usage was probably worse than the equivalent drag of axle mounted generators.
It did not take long for Amtrak to discover that though well maintained the ex AT&SF cars with their steam ejector opearted air Conditioning system was not understood by many other railroads mechanical people. That is the primary reason that the ex AT&SF cars did not stray to far from there home rails until Amtraks own mechanical people became familiar with there A/C system. Initially almost every time the ex Santa Fe cars left home rails there was a problem. The secret to the system was to maintain constant steam pressure and not to let it fluctuate. The SP mechanical forces had a particularly hard time understanding the problem and the Coast Starlight A/C failed time and time again due to SP crews not understanding the problem. The Coast Starlight was the recipient of former AT&SF cars very early.
Al - in - Stockton
What AT&SF cars were these that first went to the Coast Starlight? The Hi-Level cars, as used on the El Cap, or the standard coaches as used on the Grand Canyon and any of the Chiefs, El Pasoan, etc.?
The Santa Fe cars I refer to were the standard height single level cars that had operated in the Grand Canyon, San Diegans, San Joaquins, and the sleeping cars from the San Francisco Chief and Texas Chiefs assigned to the Coast Starlights.
Al - in - Stockton
Their long-distance pre-HiLevel coaches-- the late-40s Pullman (?) 44-seaters and the circa-1953 Budd 48-seaters. Offhand I’d guess three-quarters of the coaches on the 1972-73 Starlight/Daylight were one or the other of those.
