i want to have light bulbs in my houses, in my train room. [:D] On my h.o. scale 4FT. BY 8FT. layout. But i hate messing with the wires [:(!] , and it makes it look a mess with wires all over the table [:(!]. what should i do? [?]
you can put the wires on telephone poles, but you’d have to use very thin wires to make it look real. or you’ll have to drill holes and run the wires under the table. [:(]
I’d run the wires under the table. I use cup hooks and terminal strips to help keep my wiring neat, but there are other methods.
Enjoy
Paul
a cup hook? what is that?
A cup hook is a piece of metal like a thick wire with one end threaded to screw into wood and the other end curves in a circle that doesn’t quite close. Your local hardware store will have them. They come in various sizes usually brass. By screwing it to the under side of the layout you can use it as a hanger for the wiring.
Enjoy
Paul
i dont put light bulbs in my HO home’s i like to put LED’S in my HO home’s
Yep, LEDs have a real big advantage - they draw very little power, so you can use a dry cell to drive them. There’s no real need to even have a switch - the dry cell should last a long time, anyway. (Do tin tanks still call a battery a dry cell???)
Cheers
Allan (in Oz)
