Hello all
I am finally about to realize a life long desire to build a space dedicated just to building a HO freelance RR with approximately 100’+/- feet of main line based on the N&W. The space will be 24’x24’. The beneral plan will be have an “M” shape, single level, with a possible second level added in the future.
Here is the question. I have to bring power from the house to this building. In the start of the design process I am trying to consider all of the elcrtical needs so I can bring the proper amount of power to this building. I know I will need basics like heat, lighting. I need to figure out the power needs for the controls, lighting of the buildings, street lights, controls switches and anything I may not have consdered that I will need power for.
From your expierence what size curcuit will layout this size require just for the train ? Any thing I should consdier that I may have not thought of ? What lessons along the way have you learned that you would do differently ? Any tips that I should consder ?
Thanks in advance for your feed back.
YGW
