Good Morning,
Hope you enjoy the following, which I can laugh at this morning - but sure wasn’t laughing about it yesterday…
Last evening, I was “fixin to” wire up two sets of industrial sidings on my 3 level,15x11 Ho DC layout. I use two Controlmaster 20s, and have about 28 blocks on the layout. I am not an electrician, but I know DC wiring pretty well…
Anyway, I intended for one of the groups of sidings to be a single block, but felt that it needed two sets of leads to assure there was no voltage drop from one siding to the other. I ran the first lead and tested to assure the direction of a loco on said siding was consistent with other powered tracks, and then left the loco on the siding and shut off the power. So far, so good…
Well, then I spliced in two more leads and threaded them thru the benchwork to the far side of the siding complex. Usually, I wire the black (common) wire to the far rail and red (hot) to the near rail. Instead of “just doing it”, I decided to check for the “right” rail by using a connectivity (spell?) tester. As most of you know, this is simply two long leads with a battery/bulb in the center.
Well, I connected one lead to the black wire and touched the far rail with the other. Well, as expected, the test bulb glowed brightly. And then, just for grins, I touched the inner rail - and guess what, the bulb glowed again (although not as bright). Well, Mr. Edison here figured that I somehow had shorted out the siding complex, and the hunt was on…
I looked for tools on the tracks, and traced the few connected wires, and even assured that the sidings were isolated from the main. Yes, everthing was as it should be, but the “short” was still there. I then recalled that once I stapled some wiring under the layout and the staple cut thru the wires and caused a short, but I have not used staples since that tim
