I’m currently planning an N scale layout where I have several areas where parralell mainline tracks both branch off together (to go to another level). I am using #4 and #6 Atlas turnouts for these and, unfortunately, For the #6’s, I need a 9.5* crossing. One software program lists JHB as having a 9*, but I’ve neber heard of that company and have no idea where to purchase any. A web search turned up nothing…Also, I have seen peco has a 10* crossing in insulfrog and electrofrog. I am planning for this to be a DCC layout, so any suggestions as to whether to use the insulfrog or electrofrog if I end up using the PECO 10*? I understand the principle of Electrofrog vs. insulfrog, but never knew it was applicable to crossings as well as turnouts…
I didn’t realize that they made electrofrog crossings. Now I do.
check on http://www.loystoys.com/peco-about-crossings.html for wiring suggestions. It appears that you have to feed the acute angle frogs and this will change depending on which track you run the train on. The expensive solution appears to be an automatic reverser.If your switch machines have extra contacts, you could wire through these (won’t work if you use the machines that are moulded into the switch). Without the extra feed, an electrofrog is like an insulfrog, but possibly with a longer dead section.
Choice of electro vs insul depends on whether you run short wheelbase locos through them.
Loys Toys site has a lot of helpful wiring information for DCC.
