Electronic E Units - which is better ?
I am looking to upgrade some postwar Lionel engines to electronic e-units.
Can anyone tell me an advantage of using either the Dalle or QSI units ?
I would like the option of operating the trains in nuetral-forward-nuetral-reverse OR just nuetral-forward.
Is one unit better than the other for that ?
Thanks,
Jeff
I got a Dallee e-unit for my 2349. It was very simple to install and works great, and the instructions were easy to follow. I would recommend it to anyone. It works foward- neutral-reverse.
Dave
Dave,
Do you recall if the Dalle instructions tell you how to use a switch or jumper ot ‘lock’ a train in forward only ?
Jeff
Here is what the instructions say: " Provision is made so that a switch (not supplied) can be installed to lock the “E” unit in its initial state."
So you would need to get a switch. There is a spot on the e-unit to put in the switch. So I suppose Dallee sells it.
Any questions just let me know.
Dave
