EMD and Chevron enter agreement to explore Hydrogen fueled 710.
As mentioned in my other thread:
https://www.marinelog.com/engines-fuel/chevron-and-caterpillar-eye-hydrogen-fueled-marine-applications/
https://www.railwayage.com/mechanical/locomotives/caterpillar-chevron-team-on-hydrogen-power/
Marine looks like it would be the primary market and there are already Marine Hydrogen powered tugs in the works
https://www.behydro.be/en/home.html
https://www.rivieramm.com/news-content-hub/aip-advances-hydrogen-powered-tug-62311
The Marine version of the 710 is Tier 4 certified using after treatment.
I don’t know enough about using Hydrogen as a Diesel replacement to have an opinion. I saw that in some of those tugs, there’s support for a Diesel/Hydrogen blend as well as a pure hydrogen solution.
For the railroad application, I’m not sure what the implications are. Where is it stored? What added equipment to use it?
Is the 2 stroke 710 a better platform for Hydrogen than a 4 stroke diesel?
BNSF has jumped on to be the testing Railroad
https://finance.yahoo.com/news/caterpillar-bnsf-chevron-agree-pursue-140000967.html
They are talking about fuel cell technology the same as used on the space shuttle and international space station. Store hydrgen and oxygen in seperate containers. Mix and you get get energy and water. The electricy produced will be used to power the train. NO diesel spewing fumes all over the place.
Sounds like another “not ready for prime-time” technology.
Energy density is problem #1. Wait until you see the size of the tenders needed. Issue #2 is hydrogen permeates just about any material, so keeping it contained is going to come with a lot of compromises. And if it can’t be contained, all that loose hydrogen is another Hindenberg waiting to happen.
Are these issues insurmoutable, no. It depends upon how much railroads are willing to compromise operations to get greener. Remember the long lives of the gen-sets?
The hydrogen is in a liquid state in an insulated tank. No permeating anything and od gas untill it is used so no Hindenburg which had the hydrogen as a gas.
Look up ‘hydrogen embrittlement’ for the problem. Casual leakage is not a major issue; the greater concern is the wide explosive limits for hydrogen in confined spaces and that the hydrogen flame itself is largely invisible.
LH2 is a pretty low density liquid, with the LH2 tanks on the Centaur, Saturn upper stages and the Shuttle being MUCH larger than the LOX tanks. Another problem is that the energy to liquefy H2 is a pretty significant fraction of the usable energy in the LH2. As with liquid Helium, LH2 is cold enough to freeze air, with the extra excitement of melting frozen air is that the nitrogen will boil off before the oxygen - hydrogen and concentrated oxygen make a lovely combination.
One good thing about hydrogen is that it disperses rapidly.
Probably not as bad as installing a power reactor on a locomotive…
Seems to me that given hydrogen’s explosive nature, this creates an entirely new security issue. In High Threat Urban Areas, how tempting a target would one of the locomotive-tender setups be? BNSF has already experienced issues in the PNW with enviro-terrorists trying to derail Bakken oil trains bound for refineries.
I suspect the principal hazard with cryogenic hydrogen would be fire, but not explosion for the same reason LNG is substantially safe.
It would be comparatively easy to use a hunting rifle to put holes in the tank, but the pressure is comparatively low. You’d probably get reasonably prompt flashback to the tank but little chance of internal ignition between explosive limits. First response would by that time have the knowledge and tools to approach the tank safely, patch it, and transfer contents reasonably safely (or flare it).
If you were to hit the tank with an RPG, as terrorists would use for a TOT refinery strike, all bets would be off, but I’d expect the cryogenic state to slow the resulting to a pool fire – severe, but not catastrophic like a BLEVE.
Shooting a 4500 gallon diesel fuel tank could also have some really spectacular results, especially if one used an RPG…
I’d actually suspect that a typical hunting round through a fuel tank might not produce actual fire at all; any vapor flash would go out over the large thermal mass of the fuel and restricted oxygen through the hole after the hydraulic shock had dissipated. If shot low down you might get flaming dribble, less than a poorly-operating von Boden-Ingles burner…
The RPG was built to ‘set tanks aflame’ so yes, you’d get a nifty burst followed by a growing pool of fire and black clouds.
I suspect a nominally-invisible hydrogen fire would show all kinds of colored flame and smoke as it burned paint, ground, etc. What might be less fun would be if the fire ruptured some part of the air system at main-reservoir pressure, or if no one could safely tie the train down ‘under fire’ (no pun intended).
So what’s the assesment of this? Lots of comments that seem dismissive. Are Progress/EMD and Cheveron barking up the wrong tree here?
What about the Hydrogen tug boats. Both hybrid and full Hydrogen?
I am waiting to see what they can make of a hydrogen two-stroke conversion. The only particular difference between a fuel-cell use of hydrogen and a combustion-engine version is in the final use of the hydrogen from storage, presumably with Rankine-style exhaust heat being used to add temperature to the cryo hydrogen or displace it from hydride.
There are examples of hydrogen used in combustion motors, but the ones I have seen are four-stroke. Presumably the point is to utilize the parts and infrastructure of EMD engines, which would at least partly explain why the 710 and not the J-block 4-stroke is used as the development for proof of concept.
My opinion is that it will be as practical as bituminous pulverized-coal firing on locomotives, and the development will be marked by similar incidents…
I firmly believe the future for hydrogen is in fuel-cells charging substantial traction batteries in a hybrid configuration, with as many parts as possible in common with diesel-electrics in hybrid consist with (cabbed) BEV road slugs like the FLXdrive. Hydrogen power simply to a traction generator makes even less sense than fuel cells without energy storage.
This poster’s question is. How many BTUs does it take to make a BTU of Hydrogen? Then what is the energy recovery of the diesel unit (710 in this case). How does that compare of diesel using normal diesel fuel (710)? Recognize that the production of Hydrogen sometimes can be made from surplus electrical energy. Will there be any surplus with many electric vehicles recharging?
Are the RRs just experminating with these new type locos? That way if they fail for whatever reason the RRs can say we tried. I remember all the failed experminents. One great experiment that has succeeded is AC traction. The DPU has also succeded fairly well.
Carrier hydrogen is ridiculously profligate both in terms of energy and cost; the short-term ‘advantage’ is in mandated zero-carbon without sequestration; the longer term is unlikely to be built out without substantial Government subsidy and I suspect practically operated without subsidy. Conventional cost-effectiveness does not apply.
One argument has been that diesel fuel is itself heavily ‘subsidized’ in cost by the vast refining and distribution infrastructure for fossil oil, and that as aggregate demand for diesel and gasoline drops worldwide (with nations jumping on the BEV bandwagon wholesale with blind prayer to the Electricity Fairy to keep the electrons chugging) the whole diesrl-engine economy will go the way of big steam power as all the auxiliary manufacturers folded or retasked themselves.
Remains to be seen.
My understanding is that Renewables, especially solar, but also Wind to a lesser extent are dropping in installed price like a rock off the empire state building, there’s a point where it makes sense to develop technologies that all you to leverage the transitory nature of the generation. Using Solar to create hydrogen may not be the most efficient use of it, but it does create stored energy that is easily used when the sun isn’t shining or where the solar plant isn’t. By developing this with traditional “dirty” hydrogen generation, you avoid a catch 22 scenario.
Again, the cost to deploy solar is dropping like a rock
https://elements.visualcapitalist.com/the-exponential-view-of-solar-energy/
In 2021, unsubsidized solar makes Coal and Diesel look like a terrible energy source from a cost perspective.
Leveraging that is a major goal.
I wonder if the fact that many of the world’s solar panels are being produced by slaves in China has any effect on the price?
https://www.forbes.com/sites/michaelshellenberger/2021/05/14/biden-white-house-may-sanction-chinese-solar-slavery-panels-threatening-renewables-growth/?sh=23cde44a1319
This is utility grade solar pricing. Not rooftop so I’d say broadly no. I’m sure on the margins it matter, but that’s not the primary reason.
York,i think diving kids the resposibility for feeding the cat (and cleaning the litter box) helps them grow in maturaty.
Lithium? The US is trying to get some Li mined here but various groups are trying to delay. as a gottcha it is some of the same groups trying to push battery cars. Was reading that there is a new way to build batteries that will have much greater energy density however manufacturing problems have not been solved.
Right now Li batteries cost about $163.00 per kilowatt hour.
