Well, first of all a center- axle motor could not be added to the Blomberg AiA-A1A truck used ongthe E’s.
There was not nough room, and it a cooling duct for the other motors was already occupied that soace in the forem of a holloe area in thew truck.
So, a new truck would have to be developed pretty rapidly. EMD I don’t think produced an actual “C” truck until the advent of the SD9 in 1952. I don’t know whether Alco produced an RSD3.
The E8 and E9 locomotives, and their little brother F7 and F9’s respectively, had larger traction motors, heavier insulation, and mechanical /automatic cooloing systems,compaired with the E6/E7, and the F3.
The older models simply did not have either the electrical nor the cooling capacity for mountain railraoding.
The Alco PA had the electrical capacity, but it , as well as the FM Erie-Builts, had insufficient cooling capacity, and the PA’s 244 engine had weak cranshafts.
So, at that time, I do not think that there was a suitable “C” truck available.’ The key word is “suitable.”.
The GG-1 electric used C trucks, but to give good tracing qualities, the wheel arrrangemebt wa
s 2-C + C-2, and an unusual frame configuration that was very independently flexible, and very heavy as the pulling went trough the underframe anf trucks, and not the carbody.
Fast forward to Amrak’s SDP40-F, and it’s alleged tendency to derail at speed, and the fact that the F40 and the P42 and all the other locos built specifically for passenger service are B-B’s.
Conclusion(from Trains and other sources): The E’s were already very heavy… The extra axle was to reduce the axle load, and to provide a safe ride at high speed. It did that job well. but the E was already costly to produce, with 2 prime movers…
I think that if UP’s E8 and E9 locos did not make it in the mountains they wold have gone to F7’s and F9’s. There would have been n
